Results 1 to 11 of 11
Thread: Hello from VA
    Steve-in-VA's Avatar
    May 2015
    Smithfield/Virginia
    199
    Hello from VA
    Hey I am Steve, from VA...like the title states. I'm on the east coast and have a some screwy weather this time of year. I'm a fairly new pool owner and still learning the trick to save money. This is an expensive investment . Just signed up to get some good advice rather than just being an outsider looking in.
    21,200 gallon/ 30' vinyl round above ground pool/ 200# hayward sand filter/1.5 hp hayward pump (70gl/m) /
    /self installed pool about 3 years ago - Smithfield, VA- Pool filled with well water -TF100 kit
    Jun 2014
    15,298
    Re: Hello from VA
    Best move you could make Steve! I did the same here last year. First order of business .. get YOUR OWN test kit. See my signature below. It WILL save you lots of $$. Once you get that kit, post some test results or ask us questions and lots of people will be happy to assist. Also take a few moments to review some of the TPF helpful pages from my link(s) below. Happy swimming!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,516
    Re: Hello from VA
    Welcome to TFP! We've had plenty of crazy weather here in Texas this spring, too!
    Check out this article about Recommended Test Kits, I use the TF100 from tftestkits.net.
    Here are some of my fave Pool School articles for you to start reading.
    TFPC for Beginners
    ABC's of Pool Water Chemistry
    Here are the Recommended Levels for your pool.
    Here is the Water Balance for a saltwater pool.
    Here are the Recommended Pool Chemicals and how to add them.
    Use PoolMath to figure out how much to add.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,025
    Re: Hello from VA
    Hi Steve!
    welcome to TFP!
    Divin Dave,
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Hello from VA
    Welcome to TFP!
    Saturn94's Avatar
    Mar 2015
    Virginia
    501
    Re: Hello from VA
    Hi neighbor! Hampton here.
    Listen to these folks here. They know what they are talking about and will help you make pool maintenance easy and much cheaper than the pool store methods.
    20k IG vinyl liner/Aqua Rite SWCG, T-15 cell/Hayward Pro Grid 6020 DE filter/Polaris 280 with booster pump/Hayward Superpump 1 hp/city water/pool installed March 2004
    May 2015
    Smithfield/Virginia
    199
    Re: Hello from VA
    Hey all thanks for the welcomes.
    And hello Saturn def just a hop away. I work out of Hampton actually.
    May 2015
    Smithfield/Virginia
    199
    Re: Hello from VA
    I'll check out the links when I get to the office. On tapatalk now and seeing signatures.
    Propbndr's Avatar
    Mar 2015
    Charles City, Va
    232
    Re: Hello from VA
    Hello from another fellow Virginian and another Steve! Great name you have there. Charles City on this end.
    +1 what Saturn said.
    Steve
    32 X 16 inground, 17260 gallons, Vinyl Liner, Triton II TR-60 filter,
    Sta-Rite 1hp pump Model #MPRA6E-147L, CircuPool SI-30 Plus SWG, TF-100 Test Kit
    DaneCE's Avatar
    Jul 2011
    VA
    280
    Re: Hello from VA
    Chesapeake here.
    Welcome to the pool owners best friend.
    May 2015
    Smithfield/Virginia
    199
    Re: Hello from VA
    Wow... Nice to know there are "locals" on a forum with so many members. And thanks for the welcomes
