Thread: still seeing algae after 5 days of shock
    May 2015
    Overland Park, KS
    14
    updated in SLAM thread. mods delete
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: still seeing algae after 5 days of shock
    What is your CYA level? Are you brushing the pool daily or more often? How much chlorine are you losing between tests, and how long are you going between tests?
    May 2015
    Overland Park, KS
    14
    we've been losing a lot less FC lately (which to me is a good sign). we started testing it every couple hours this weekend. would have to add a couple gall of bleach every time. lately though, after a whole day its only dropping by 2-3 ppm or so. so it's becoming easier to maintain the FC. brushing and vacuuming are pretty routine occurrences for us now. its starting to wear me out lol. will have to look back at what CYA is at (IIRC it was around 30). will see if my fiance remembers off hand since i'm at work
    Donldson's Avatar
    NW Ohio
    2,917
    You already have a thread going about this SLAM. Please keep everything together so we don't have to go looking at your previous posts to see what you have already done and the test results you have already posted.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    May 2015
    Overland Park, KS
    14
    yea... will update there. as well. mods delete if u want
