Thread: Plywood under backerboard
    Must I have a plywood base under half inch hardibacker for the countertop? Used 2x4s laid flat to create the countertop support and overhang, max space between them is 20 inches. Most are 16 inches or less. Can I just lay the hardibacker over the supports or am I looking for trouble with flexing?
    Jun 2011
    Carlsbad, NM
    172
    Re: Plywood under backerboard
    What do you have planned for the countertop material? I used 2 sheets of 3/4" plywood covered by 1/2 hardi for my marble tile countertop.
    36' x 18' 20k in ground, Finest Finish grey plaster, Pentair Tagelus 100D sand filter, Hayward Northstar 2hp pump, Jandy LRZ125EN heater, spill over spa, iaqualink controlled automation, Stenner chlorination, natural rock and flagstone coping, 1" glass mosaic waterline tile, SR Smith Vortex slide.
    Just porcelain tile
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    I built a grill island that looks built-in, but it is portable with large hidden casters underneath. I installed plywood and then 3/8" backerboard on top of that. I then installed outdoor-rated ceramic tile over that. Grill island is 10 years old and moved with us to our new house. No cracks in the tile.
    Now if yours is stationary, you probably can get away with just the backerboard, but I would definitely go with the thicker backerboard.
    cwescapexlt4x4's Avatar
    Jul 2014
    Litchfield Park, AZ (PHX metro area)
    461
    i have several steel studs running across the top, then 1/2" backer board and 12" sq granite tiles - no issues so far.
    Chris - aka cwescapexlt4x4
    (Build 8/26/14 - 10/17/14) in-ground Presidential Pools 15K gallon salt water pool Pentair Inteiliflo pump, Regal Blue Pebble, Clean & Clear filter, in-floor cleaning,
    LED light, 3' sheer spill, 2 benches, large Baja step. / Pergola by Booth Built 19W x 14D // Outdoor Kitchen, W/Primo grill and BBQ Coach kit for the island.
