Results 1 to 8 of 8
Thread: what is the highest FC level in which it is safe to swim?
    May 2015
    wadsworth, IL
    9
    Is it safe to swim while SLAMing the pool?
    AG, 12 x 24 ft oval, 7700 gal, sand filter
    ship of fools's Avatar
    Nov 2011
    Albany, NY
    496
    Re: what is the highest FC level in which it is safe to swim?
    Quote Originally Posted by grahahw View Post
    No - it is safe to swim as long as you are below SLAM level for your CYA level.
    21,000 gallon inground
    Haywood Sand Filter
    Vinyl Liner
    May 2015
    wadsworth, IL
    9
    your answer appears to include both yes and no responses to the question
    Is it safe to swim if the pool is at the SLAM FC level for the CYA level?
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,025
    Grahahw,
    it is safe to swim if FC is < 40% of the CYA level AND you can see the bottom of the pool.
    Divin Dave,
    Nov 2011
    Albany, NY
    496
    Search this site and you will see it repeated over and over. If you are BELOW SLAM level as i said. So if your level for your CYA is 20 you can swim up to 19 and so on.
    Haywood Sand Filter
    Vinyl Liner
    May 2014
    Clarksburg, WV
    331
    BUT, you dont want to be swimming if you are slamming and you cant see the bottom....Or if it just looks nasty cloudy in there. At least I wouldnt swim in that.
    24'x54" 15k AG round - Outback Genesis
    1 1/2hp Hayward Matrix 2 speed. Hayward 180T Sand Filter
    TF-100 Test Kit
    Pool School & TF-100
    How to SLAM
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    OR...if the CC is 1.0 or more....
    Essential Links:
    38,532
    OR ... if the FC less than the minimum for your CYA level
