Thread: EC 65 DE filter
    May 2015
    roseville, ohio
    2
    EC 65 DE filter
    my filter has plenty of pressure but I am concerned that you can still bump it while the pump is on, then when it is off you can tell that when bumping it , it is not working correctly.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: EC 65 DE filter
    You should not be able to bump it when it is on.
    "not working correctly" meaning what exactly - what are you experiencing specifically?
    May 2015
    roseville, ohio
    2
    Re: EC 65 DE filter
    yes, when you are to bump it when it needs cleaned, the handle should have a little pressure on it, not just bouncing up and down, I have had it for years. but was wondering if it might be missing the little metal clips inside the lid, I can not remember if it takes two and if so where they go
