Thread: "Vandals turn pool water yellow"
    I don't often read threads in the Baquacil section, but the pictures are always highly entertaining.
    Reminds me of this news story from a couple years ago: "Vandals turn pool water yellow; cost family thousands"
    Note that this is from two years ago, so no need to call the station to explain to them what most likely happened. I expect the situation resolved itself soon after the story was broadcast.
    25000-gallon semi-public IG concrete/plaster pool, Triton II sand filter
    750-gallon semi-public IG concrete/plaster spa, cartridge filter
    Volunteer pool caretaker for my condominium complex
    Propbndr's Avatar
    Mar 2015
    Charles City, Va
    232
    Re: "Vandals turn pool water yellow"
    I wonder what they poured in the pool that turned it that yellow.
    Steve
    32 X 16 inground, 17260 gallons, Vinyl Liner, Triton II TR-60 filter,
    Sta-Rite 1hp pump Model #MPRA6E-147L, CircuPool SI-30 Plus SWG, TF-100 Test Kit
    Look at some of the photos in this Baquacil sub-forum, and you'll see. No vandals. It was just an owner mistake. Or a helpful friend who didn't ask questions first.
    I don't think that it is baquacil related. It doesn't look like any color that I have seen. However, I don't have any idea what was added to make it do that. The report says that the water was going to be tested to determine what the cause was. Perhaps contacting the The Oklahoma Department of Agriculture would provide an answer.
    Support the site
    Jul 2014
    Albertville, MN
    21
    Whatever it was stained and killed the grass. Pretty sure that would not be a result from Baquacil.
    Semi Above-Ground - Radiant Metric (24')
    Hayward H150FDN Universal H-Series Low Nox 150,000-BTU Natural Gas Pool Heater
