Thread: Still getting sand in pool
    May 2015
    Maricopa, AZ
    2
    replaced the laterals in the sand filter and still getting sand in pool. can it be the hub? appreciate any info. TY
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: Still getting sand in pool
    Hi, welcome to TFP!
    I am not that familiar with sand filters but maybe this tutorial on cleaning sand filters will help, Deep Cleaning a Sand Filter
    Mar 2015
    Louisville, KY
    32
    I had this same issue although I replaced the entire stand pipe assembly as well. I did this a few weeks ago and I'm still getting sand in the pool. Its not a lot, but it is still annoying...I'm not sure what else could cause the problem. I'm just dealing with it I suppose....its not a huge amount of sand but it can build up between cleanings.
    18x36 Fox X-Brace 28,000 gallons Inground Pool, Pentair Sand Filter model TA60D, Whisperflo WF-24 pump, PoolFrog 5400
    DFW, TX
    24,497
    Here is a process for backwashing a sand filter that mentions using a rinse function that might help with the sand issue. Pool School - Maintenance and Cleaning of Pool Filters
    May 2015
    Maricopa, AZ
    2
    thank you very much. I will try this.
    May 2013
    Long Island NY
    419
    I think you also should check the multi port gasket, at least you would know for sure that it wasn't the problem. At least you could see what kind of condition it was in. I replaced mine last yr. easy to do.
    19,000 gal - Vinyl IG - Sand filter -1.5hp. - Taylor k 2006 - Loop Loc cover
