Results 1 to 15 of 15
Thread: Measuring Pitcher Suggestions - Do i even need one
    caliskier's Avatar
    Aug 2014
    Oklahoma City, OK
    231
    All,
    i am starting to get the hang of this TFP method, but have a question... Pool math says, hey add 1.2 jugs or 1 gallon and 2 cups. Has anyone gone out and bought a 1 gallon graduated pitcher? Hard to eyeball a 0.2 of a jug. Does it matter if I go 0.4 or 0.1?
    Let me take an extreme approach. Say PM says add 1.2 jugs, and I add 5 jugs, I assume I just wasted a bunch of chlorine as it will evaporate out of the water before being useful, but say PM says 1.2 and i put in 1.5 did I waste the 0.3?
    Owner since August 2014. 21,500G Liner In ground Pool with attached 600G plaster in ground hottub. TF-100 Test Kit, Filter: Pentair TA60D Clearpro Sand (HTH) Filter. Pool: 1 Drain, 2 Skimmers 4 Returns. Hot Tub: 1 drain, 1 skimmer, 2 returns. Hot Tub/Pool run by Sta-Rite Dura Glas Single Speed 1.5hp P2RA5F-182L pump with Emerson K63CXESE4972 motor. Spa jets run by Sta-Rite Dura Glas H/L model number unknown.
    Re: Measuring Pitcher Suggestions - Do i even need one
    Just use the nearest whole jug or estimate. No need to be exact. Better to be a little high, than low.
    Support the site
    38,407
    I usually estimate to the nearest 1/4 jug ... good enough in a pool your size.
    BTW, chlorine does not evaporate. It is true though that if you raise the FC well above the target levels for your CYA, you will lose more ppm of FC to the sun. a simplified way to think about it is that your CYA level sets the % of FC that is lost to the sun each day. So the higher the FC level the more ppm you will lose.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,572
    I have a 2.5 cup measuring cup just for the pool. I keep it with my chlorine. I go by ounces. Of course I do tend to go over as some of it over spills but that is fine with me. Like stated above better to go a little high than too low.
    OH and do NOT use the cup your use to put chlorine in as the cup to take water out to test. Do not ask me how I know LOL I wondered why my FC was sooooooooo high!
    Kim
    caliskier's Avatar
    Aug 2014
    Oklahoma City, OK
    231
    Thanks all!
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    I guess I'm a bit on the OCD side when it comes to measuring ingredients, so I have 32oz and 64oz acrylic measuring cups. You can get these at restaurant supply houses (brick & mortar or online). To prevent cross-contamination with cups used to measure out food, we have this rule at our house...Glass cups are for food only. If it's not glass, it doesn't get used for measuring out food.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,187
    I am a believer that exact measurements for chlorine or muratic acid are just another step to cause a spill. I use a "best guess" method and free pour from the jug.
    Support the site
    May 2014
    Clarksburg, WV
    331
    I too go by cups/oz instead of jugs or quarts or whatever. I have a 8 cup container that i use. And I can be a perfect example for you. My CYA is 35 and my FC target is 4. I try to stay above 3 and below 5. If I get up to lets say 6...I'll be back at 4 by 8pm. BUT, then i'll stay at 4 for another day or maybe even 2 with no swimmers. My magic number is between 3 and 4. It tends to stay right around that number for the most part. If I go high, I waste. So when I finally drop to 3, i shoot for 4.5 or 5. Which in my case is usually about 3-3.5 cups or 30-35ish oz. And now that i have this system down pretty well. I only have to add that every other day....Sometimes I can go 3 days. I set it at 5 on Wednesday night.....I was at 3 again on Saturday....I added 3 cups on Sat night. Tested last night....I was at 4. Ive added roughly 6 cups of bleach in 6 days.
    And i'll tell ya....They were not EXACT cups either. I had a point when I started this rant.....But i'm not real sure what it was....lol But I hope it helped!!!! Good Luck
    24'x54" 15k AG round - Outback Genesis
    1 1/2hp Hayward Matrix 2 speed. Hayward 180T Sand Filter
    TF-100 Test Kit
    Pool School & TF-100
    How to SLAM
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by BoDarville View Post
    I'm with Bo. I like to measure even though I know now pretty well the exact outcome of what I dose. Most of my additions are in the 60-100oz range, but I tweak, and like to be precise. Can't help it. It's a little OCD and background for me. I have an old one gallon graduated pitcher that gets used for nothing else except pool chems and it stays out in the pool chem dilution bucket. No chance of it going inside for use on anything else.
    Essential Links:
    The only thing I use a measuring device on is Baking Soda. Chlorine is in gallons and Acid is 1/3 of a gallon.
    Sent from the bat phone near a drilling rig.
    May 2015
    River Falls, WI
    124
    I like to measure my doses fairly closely. I grabbed a plastic pitcher and put a piece of shipping tape on it and then took a measuring cup and water and kept dumping 8oz increments and marking it manually on the tape. Then I covered that piece of tape with another to keep it from smearing. I don't know how long the tape will last, at the same time, I completely dunk and rinse the pitcher and it seems to be holding fine for now. I suspect I'll end up grabbing an etching tool at some point and making the marks permanent. For now it works fine though.
    ~19k Gal, IG Vinyl, Hayward SP2607X10 1hp pump, Hayward S200 Sand Filter, built in 70s, has 8 deep end with diving board, 1 skimmer, 1 return, 1 low hole, Polaris booster pump PB4-60, old Polaris robot not sure model, Rheem P-M266A-EN-C 266,000 BTU heater, solar cover, Taylor K-2006 test kit, Speedstir
    The reason I don't is my pool uses 1 gal of Bleach every other day with normal swimming in the summer and 1 every day with a pool party. Acid is once a week summertime. My cup for the baking soda is 16oz and I usually add 64 at a time which is approx 10 ppm.
    Mar 2013
    CT
    351
    This is what I use. Works great.
    http://www.agrisupply.com/measuring-pitcher/p/70246/
    16 x 32 In-Ground vinyl, 21,000 Gallons, Hayward Cartridge Filter, Hayward Tiger Shark robotic cleaner, Taylor K-2006 Test Kit
    caliskier's Avatar
    Aug 2014
    Oklahoma City, OK
    231
    Quote Originally Posted by kris77 View Post
    6 cups in 6 days is amazing. How many gallons is your pool. No, 15,000
    Quote Originally Posted by dschribs View Post
    That's what I am lookin for, thx
    Quote Originally Posted by wrems View Post
    This is what I was thinking of doing until I say the link above
    Sep 2014
    Fort Lauderdale, FL
    146
    I bought a measuring cup at ikea for pool use. I may have used it twice. I find it easier to eyeball chlorine amounts (usually 1/2 gal increments). Acid fumes are too nasty to take time to measure, so that's estimated at a slow pour.
    15k in-ground plaster, Hayward C900 cartridge, 1.5hp Pentair SuperFlo VS pump, Hayward AQR15 SWG, Barracuda G2 suction cleaner, TF-100
