Thread: when to run the pump
    May 2015
    Monroe/NJ
    76
    I have a SWG and a heat pump. Should I run the pump 8am-8pm to generate chlorine during the day, or should I run it 8pm-8am to maintain the pool temp via the heat pump (and pool cover) at night?
    The pool company told me to run during day but I don't trust them with anything anymore!
    Inground Pool Completed April 2015
    Salt Water Generator- Nature 2 Fusion Soft
    33,500 gallons, Gunite/White Plaster
    Cartridge Filtration
    Heat Pump
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: when to run the pump
    There are some advantages to running the SWG during the day while the sun is shining on the pool. Unless there is some other reason not to run the pump during the day, like time of day electric rates that are higher during the day, program the pump to run while the sun is shining on the pool.
    More info can be found here: Water Balance for SWGs
