Results 1 to 12 of 12
Thread: 1st Salt Purchase
    Feb 2015
    Austin
    133
    1st Salt Purchase
    My SWG pool won't be finished for a few weeks, but I have a good Lowe's coupon expiring today and I want to stock up on pool salt. I'm looking at the Diamond Crystal 40-lbs Pool Salt bags. Should I buy as many as possible or not a good idea? I don't have a good grasp on exactly how much salt I need per month.
    Shop Diamond Crystal 40-lbs Pool Salt at Lowes.com
    36 x 16 IG, SWG, FAFCO Solar Heating System, WetEdge Primera Stone Sky Blue Treasure, 8.5' - 3.5' depth, 6' S.R. Smith Flyte-Deck II Dive Stand, Interfab X-Stream slide, 27k gallons, doggy tanning ledge w/ 2 bubblers, 2.75 Hayward Tristar pump, Hayward 425 cart filter, Hayward T-15 Salt Cell, Hayward ColorLogic 4.0 light, Dolphin Z5
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,943
    Re: 1st Salt Purchase
    You will put salt in the pool once to bring it up to the reccomended level. After that you will need no more salt. Do you know the volume of your pool?
    Salt stays in the pool. It doesn't evaporate or get used up. The only way you need to add salt is due to splash out or draining water.
    chiefwej
    4knights's Avatar
    NE Kansas
    419
    ^^^^ or salt gets diluted due to tons of Rain!! (Pool overflow conditions) 9 inches overnight in some parts of Texas.
    Ron- Kansas. IG fiberglass, Riviera 30 Freeform 13600 gallons,
    EasyTouch 4 w/IC20 SWCG, Pentair Whisperflo 1hp, 2 speed 220 pump, Hayward ProGrid 4820 DE filter using Eco Klean instead of DE, 2 Savi Melody 12v 5 color LEDs, Raypack 266k btu millivolt heater, Arctic Armour Mesh custom safety cover (Total self Install) TF-100 test kit w/Magic stir.
    Feb 2015
    Austin
    133
    Quote Originally Posted by chiefwej View Post
    Do you know how many bags I need? My pool is 27k gallons. Also, can you use Diamond Crystal Salt Pellets instead? They are $1.50 cheaper per bag.
    Shop Diamond Crystal 40-lbs Salt Pellets at Lowes.com
    4knights's Avatar
    NE Kansas
    419
    Pool math will tell you exactly how much as well as how much water your pool may have based on dimensions.
    If you actually have 27000 gallon pool with NO salt- pool math says 737 pounds. I'd go 2/3rds brush/ circulate for 24 hours test then add.
    Feb 2015
    Austin
    133
    Quote Originally Posted by 4knights View Post
    Sounds like 20 bags should cover it then. I did some searching online and in this forum, but found no definite answer on using "Diamond Crystal 40-lbs Salt Pellets". Hopefully they'll work OK.
    Feb 2015
    Austin
    133
    Looks like my Lowes coupon expired ay midnight in some other country. No need to go with lowes then.
    It seems like many people here refer to "solar salt" at Lowes/Home Depot ubiquitously. There are several brands at different prices. This Diamond Crystals Solar Naturals Extra-Coarse Water Softening Salt is the cheapest Home Depot carries, and according to several threads here, some people are using it. Ok for use? I don't see any additives in the ingredients list.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,468
    Yes, pool salt or solar salt from lowes, home depot or the pool store is fine. Use PoolMath to calculate how many gallons your pool is and then how much salt you need to get it to the recommended PPM for your SWG, most SWG want salt somewhere between 2800 ppm and 4000 ppm. Your owners manual will tell you the ideal number. Do NOT assume your salt level is 0 in your pool. Lots of things add salt to pools over time.
    Feb 2015
    Austin
    133
    Quote Originally Posted by pooldv View Post
    Good deal, thanks. I can get those blue bags for $3.50 a piece right now, so I'll stock up.
    Feb 2014
    Upstate, NY
    390
    Quote Originally Posted by tedujam View Post
    Wow, the Diamond Crystal Solar salt (Blue Bag) is 5.38 here in NY at my local Home Depot.
    20X36 IG vinyl (18,000 gal), 3 sheer descents, Max-Flo 1.5hp VS 2300, Aquarite T15 SWG, C3030 filter, 250,000 BTU heater, Sharkvac XL (Hayward equip)
    jmcdtucson's Avatar
    Jun 2014
    317
    Be sure to test your water before adding the salt. Lots of municipal supplies have a fair amount of salt to start and you can end up with too much salt if you base your calculations on salt-free water to start.
    Intex 12'x24'x52"
    8,403 gallons
    Intex SF60110 2450 GPH Sand Filter
    Intex CS8110 SWG
    Aquabot AJET121I Pool Rover S20-40
    skylar18's Avatar
    Apr 2013
    Austin, Texas
    299
    That is exactly the salt i use. You are good! Good advice in the above post. My pool builder was going to add way to much salt until I stopped him and showed him how much salt was already in the water. If I remember right it was almost 1000 ppm
    43 x 19 Gunite Pool w/ spa and fire pit, 19,000 gallons, Pebble Sheen Aqua Blue finish, Jandy 2 HP VS E-pump, Jandy 580 sq ft Cartridge Filter, Jandy LXI 400k Heater, Jandy Aquapure 1400 SWCG, 4 Jandy LED color lights, Aqualink PDA and Iaqualink, Polaris 280 with Booster Pump. Polaris 9550 Robot Cleaner. 1 HP Silencer Air Blower for Spa http://www.troublefreepool.com/threa...NAL-INSPECTION
