Thread: Rheem 106k heater
    Jul 2013
    Chicago IL
    83
    Rheem 106k heater
    Just had the gas line run for my new Rheem 105k heater , Fired it up , seems like water been gaining about 1deg per hr. , seem right??.. Water from return seems somewhat warm.
    15ft Round, Above Ground , Rheem 106K Heater , Black Diamond 90 Cartridge Filter, Pool Frog(disconnected) ,TF-100, City of Chicagos finest H20
    Re: Rheem 106k heater
    In an ideal world you could get as much as 2 degrees per hour, but 1 degree per hour is very reasonable for the real world.
    The water returning to the pool will only a couple of degrees warmer than the pool water.
    Jul 2013
    Chicago IL
    83
    Would i want to keep the heater on constantly until it hits the desired temp (85deg) ?? Or can i get it up to like 79 ,put solar cover on overnight , then turn it back on early morning ?
    Put the solar cover on regardless.
    If you won't be swimming until afternoon, you can probably get away with turning the heater off overnight, but total energy usage will be similar and many people prefer not to run any risk of not being up to temperature when you want to swim (and thus leave the heater on).
