Page 1 of 2 12 LastLast
Results 1 to 20 of 26
Thread: Much higher chlorine than expected
    Rocklin, Ca
    467
    I have a 25000 gallon pool that has been full since the end of July and running with the SWG since the beginning of September. I have been slowly tuning the numbers but have been increasingly more troubled by the SWG settings vs CL output.
    I have an IC-40 that was purchased by me on eBay and installed by the PB. It has been on since day 1 but wasn't producing chlorine until I dumped the salt in starting on 9/4. This all seemed very normal to me. After I dumped the salt in and tuned the Intelliflow for enough flow to keep the flow light green I thought I was in business.
    The PB had set the initial SWG output to 80% which resulted in CL levels of near 10. I have been slowly reducing the SWG output and then testing the CL levels a day or two later and repeating. I am now at a point that makes me suspicious that something is not right. Please note that due to cold temps we have not been swimming for about 30-35 days so swimmer load is not a factor. Also there is little to no organic material entering the pool. My 4X160 has been running at 1300RPM from 7:00AM until 3:00PM seven days a week for many weeks now. The water has always been crystal clear.
    Here is the mostly complete history
    DATE..........CL.......SALT.....TEMP......NOTES
    9/4............6.5......1770.......79.........after adding 250# salt
    9/10..........5.5........3000......78.........after adding 250# salt
    9/12..........4.0.................................added acid and 100# salt
    9/17..........1.5........3500.......79
    9/23..........9.5.....................74.........added acid and CYA
    9/24...............................................reduced SWG from 80 to 60
    9/25...............................................reduced SWG from 60 to 50
    9/26.........11.5
    9/30.........10.0.....................76
    10/6...........9.0.....................70........added 36oz 31% HCL
    10/12.........7.5.....................58.........added 32oz 31% HCL
    10/13
    10/17...................................62..........added 30oz 31% HCL
    10/19...............................................reduced SWG to 3% added 50# salt
    10/20.........7.0.....................60
    Here's the latest full set of numbers taken with the TF100
    FC........7.0
    CC........0.0 It's never been anything but 0.0
    TC........7.0
    pH........7.5 I keep it between 7.4-7.6
    TA.......100
    CH.......330
    CYA.......80
    SALT...3500 Not measured since adding 50# last weekend
    TEMP......60
    Ok that's all the background info...now for the questions. Do I have a problem with my SWG? Is it normal to run at 3% and still get a CL of 7.0?
    Thanks
    Kevin
    11000 Gals, Intelliflo, Sta-Rite Cartridge, Polaris 360
    Pool I built in my old house: my-new-pool-build-t4534.html
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Much higher chlorine than expacted
    Quote Originally Posted by cobra46
    CYA 80
    Cold water, no swimmers, no organic load and 80ppm CYA probably equates to very little chlorine consumption.
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    I've got a customer with a Jandy Aquapure that we normally have to run between 0-1% It's an indoor pool, oversized ozonator, very little bather load.
    You're lucky you have the easy touch to control production vs. depending on the intellichlor controls. Wait until summer rolls around to get a good feel for how well sized it is.
    Rocklin, Ca
    467
    Re: Much higher chlorine than expected
    Thanks
    This makes me feel a little bit better. It seems like most of what I read shows people running SWG's at a much higher percentage
    Aug 2008
    Phoenix, AZ
    26
    I had to turn my SWG down to 15% running 6 hours a night to get my FC down to 3 ppm. At 30% for 8 hours I had FC of near 10 ppm.
    15,000 gal Freeform Salt Water (SWG), Pebble Sheen with in floor cleaner. Hayward 1.5hp pump and 425sq ft Hayward Cartridge filter. 35sq ft Waterfall with separate 1.5hp Hayward Pump.
    Rocklin, Ca
    467
    Two nights ago I changed from 2% to 1% and still measured 6.5ppm last night. I am running 8 hours. I may have to try and only run the SWG for part of the total pump time if that's possible. I suppose I could just dial the speed down so the flow switch shuts the SWG off.
    It can take several days for the FC level to stabilize after you change the percentage. Keep an eye on the FC level, it may well go down further.
    You might also want to lower the pump run time. As the water cools you don't need to run the pump nearly as long.
    stever's Avatar
    Nov 2007
    Escondido, CA (near San Diego)
    285
    I too had/have the same issue.
    I got salt in the pool at the beginning of September and the PB set the IC40 to 80%. The chlorine was well over 10 ppm in no time. I lowered to 60%, then 40%, 20%, 10% and just lowered to 8%. I'd bet I end up at about 3-4% once I'm done, I just don't want to lower it too much (as Jason said, it may take a while to adjust). Until today, it's been covered, with no swimmers for a month, no organics, but a load of dirt from the landscaping.
    I run the pump for 1 turn/day. This is 15 gpm for the cleaner for 4 hours overnight and about 28 gpm for 12 hours during the day. I'm not sure it the SWG is working while it's being cleaned at night (15 gpm) -- I'm usually not awake at 2:00 AM through 6:00 (except when the cleaner climbs out of the pool and I awake to a giant sucking sound and the pump re-priming.
    The IC40 is oversized for the pool. A good lesson for those looking at it but not considering the Intellitouch or similar controllers. If not, then it would be 20% or nothing.
    Steve
    Pool: 625 SF Free-Form In-Ground Shotcrete Pool w/7.5' dia spa.(8 jets), 24" raised bond beam (22,500 gal)
    Pentair Equip: Intelliflo VF Pump, MasterTemp 400 Heater, IC40 SWG, Quad DE 100 Filter
    Automation: IntelliTouch i7+3 (+ extender panel), 6 Jandy Automated Valves (S, R, Spa Bypass, Solar, Cleaner, Spillway)
    Other: 75% Solar, Kreepy Kruiser Cleaner, Tan Hip-Hop Diving Board (a bit curved) on 606 Cantilever Base (SR Smith)
    Links: [TFP Pool Build Thread] - [TFP Landscaping Thread]
    Rocklin, Ca
    467
    Steve,
    I will keep you posted how mine turns out. Our pools are similarly sized. I don't know my flow rate but have been running my pump as slowly as I can and still keep the SWG flow light green.
    Kevin
    stever's Avatar
    Nov 2007
    285
    Kevin,
    I checked, and the SWG is off at night at 15 gpm (not surprisingly). The manual states 20 gpm is the minimum. The way it's chlorinating, I'm not sure I want itt running at night -- the less the better. But seriously, I believe it's better at 2% all the time instead of 4% half of the time -- more even flow of chlorinated water entering the pool.
    I'm overchlorinated at 10% 12 hours a day (72 minutes of SWG total).
    Am I doing my math right? If the SWG has a 10,000 hour life and it runs for 8% a day for 12 hours (1 hour on/day) that works out to a 27 year lifespan.... seems pretty high. I'd guess that it'll fail some other say before then, but I'll be happy if I get 10 years.
    Steve
    Rocklin, Ca
    467
    I've been running mine during the day. My thinking is that I will be producing chlorine at the same time that the sun is comsuming it.
    I was real busy over the weekend but I will be testing tonight. I'll let you know my new numbers at 1%.
    The amount of Chlorine needed is directly related to pool water temp. It goes down very fast
    with water temp. Water temp of 65 deg needs little chlorine added to maintain the
    chlorine level. The opposite when the water temp increases. Above 78 deg the amount
    of chlorine needed raises rather rapidly with water temp.
    Many of the SWG's have a temp. compensation built in to slow down chlorine
    generation as the water temp. falls. If yours doesn't have this feature
    then you will have to run the SWG a shorter amount of time or turn down the
    output.
    Be sure to write down the settings you need, then all you will have to do is change the
    settings with the seasons. It will take w while to come up with the settings that work with
    your pool, seems as though every pool is a little different.
    Cliff s
    Ft Lauderdale, Florida
    1,455
    I may be mistaken, but AutoPilot is the only one with the automatic temperature compensation, as it's a patented feature.
    Having said that, everyone elses system has a cold temp cut off, that shuts down the system when it gets too cold...except AutoPilot. We lower the output to 1% at around 55 degrees or colder.
    The mechanics of the salt generation process does "reduce" the amount of chlorine produced slightly due to the cold temps, but is not a temperature compensation. That's why you have to manually adjust the output of the system as it gets colder with other systems, otherwise you tend to overchlorinate...which takes us back to the original post.
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    Sean,
    As I understand it, the reason other units cut off at cold temps is that the cell is unable to do the math on what the salt level of the water is. Does the AutoPilot still measure salt levels accurately below 55 degrees or does it default to 1% because there's little risk of damage at that production level even if the salt is too low/high?
    Thanks!
    Tim
    Rocklin, Ca
    467
    I checked it again last night after several days at 1%. Here's the numbers.
    FC......5.0
    TC......5.0
    pH......7.5
    TA......90
    CYA....80
    Temp...61
    Water looks awesome.
    I think I will reduce the run time from 8 hours down to 6 and see what happens. I'm shooting for a CL of about 4. If the CL drops lower than 4 I'll just bump the SWG up a bit.
    stever's Avatar
    Nov 2007
    285
    Hmmm. At 1%, 'bumping up the SWG a 'bit' is doubling its output by setting it at 2% -- might have to be an adjustment in run-time. But I know what you mean. I'll check mine this weekend -- it's at 4 % now.
    Steve
    1,455
    Quote Originally Posted by spishex
    Sean,
    Thanks!
    Tim
    There are few systems that have true salinity sensors to prove an accurate salt reading. Most are determined by estimating the salt level, based on the cell amps and volts. The AutoPilot's salt sensor is temperature compensated so it it stays accurate under cold water conditions.
    The reason most systems cut off under cold water temperatures is that the the electrolytic reaction starts to make more oxygen than chlorine, there's slightly more wear on the cell if the output setting is not reduced (cell run time), and the cell voltage tends to increase (causing a higher power load on the power suppy). So you can see that there is, in fact, more damage that can occur at cold water conditions on the cell and the power supply. Thus the cold temp cutoff.
    However, adding more salt to maintain the upper end of the recommended salt level, can help a cell continue to operate under cold water conditions that would normally turn off the cell.
    Jul 2007
    Brisbane, Australia
    874
    our chlorinators have a temperature compensation, but it works totally opposite to what Autopilot does
    it produces the same amount of chlorine no matter what the conditions are
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    Quote Originally Posted by Strannik
    Does what totally opposite? Measures or produces?
  20. Back To Top    #20
    Jul 2007
    Brisbane, Australia
    874
    produces
    in Australian market clients don't like to see output changing with temperature, plus we don't get such temperature change as you guys
