Results 1 to 7 of 7
Thread: Hayward filter seemingly low PSI
    May 2015
    Ottawa, Ontario
    3
    Hello, we've had our brand new pool open and in use for about a month now and I've noticed that the Hayward Swimclear Cardridge Filter seems to have low PSI all of a sudden. It's hovering around the 2-4 range when our Hayward Ecostar variable speed pump is running 1380RPM. If I recall correctly it was averaging 15PSI when the pool was first opened and equipment hooked up.
    I've had to vacuum some topsoil and worms from the bottom of the pool a few times recently as we're doing some landscaping around it and the wind swept it in. Could anything like that be causing the low PSI? Is this something to worry about or is it better than having high PSI?
    The pool is only 14' x 25' with a 7' deep end of that helps at all. Water is also crystal clear. Chlorine is a bit high but everything else is reading regular.
    Thanks in advance
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: Hayward filter seemingly low PSI
    Generally larger filters mean lower psi and low psi is good. It means your pump doesnt have to work as hard to pump the water through it.
    Do you know the model number of the filter?
    2030? 3030? 4030? etc... this will tell us how large the filter is and give a better idea of the pressure is expected.
    As an example, with my VS pump running about 1500 rpm, my 430 sq ft cartridge filter only shows about 2 psi.
    Divin Dave,
    May 2015
    Ottawa, Ontario
    3
    Thanks so much for the quick response. My model is 3030.
    Hayward Pool's Avatar
    Oct 2014
    Elizabeth
    426
    Low psi is normal when running an EcoStar at low speed. What is the PSI at high speed?
    Hayward Pool Tech
    80+ Years of Technologically Advanced Pool Product Manufacturing
    poolside@haywardnet.com
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Yep, I crank my pump to 3100 to check filter pressure to see if I need to clean.
    May 2015
    Reynoldsburg Ohio
    10
    I'm brand new to this forum, but joined to ask this same question. I started another thread somewhere. I also have a Hayward pump, but a smaller pool than you. My psi is 2-3 and backwash is 0. My pool is a small INTEX 5,000 gal. Can't wait to keep reading responses.
    May 2015
    Ottawa, Ontario
    3
    At 3105RPM it climbed to 20PSI, so I guess it's working as intended, eh?
    Thanks for all the replies everyone!
