Thread: Time for a New Multi-Port Valve/Spider Gasket?
    Jul 2014
    Hudson Valley, NY
    13
    So last year was the first year in our new house with a pool, and I spent much of the season last summer chasing down various leaks in the plumbing as a result of lengthy neglect by the former owner (house was a rental for a number of years). I replaced all the plumbing (one suction side, one return). The filter is an old Hayward DE - the kind that they no longer make the metal clamp for anymore. It's pretty beat up, and though I may replace it, I could probably squeeze another season or two out of it if I treat it nicely.
    But here's my question. I don't know what kind of abuse was thrown at this multi-port, but it's clear the gasket is thrashed. I've been trying to remove it, but it appears to have been glued in place and is proving to be a real pain to remove. Also, there appears to be some plastic missing inside the multi-port, and what's there is brittle. Without question I need a new spider gasket, but I'm wondering if at this point it makes sense just to replace the whole thing. Or, assuming I can remove the gasket, is the valve still serviceable in this condition (with the missing plastic)? Here are some photos:
    Approximately 25,000gl, IG, built late '90s, 5 yr. old vinyl liner, Hayward 4800 DE filter, rebuilt Hayward 3/4 hp pump, Hayward CL200 canister - all poorly cared for by prior owner.
    Scottaustin26's Avatar
    May 2015
    Houston, TX
    32
    Re: Time for a New Multi-Port Valve/Spider Gasket?
    Could you post a couple more pictures? I would probably say replace the whole thing, just because it looks shot. I can't tell without some more pictures.
    14.5K gallon IG plaster pool, 1K gallon spa, dual 2hp Jandy pumps, 60 sqft DE filter, 400K BTU NG heater. Dual waterfalls, Jandy Aquapure SWG, Polaris cleaner with 3/4 HP pump, Aqualink RS. See my pool here.
    Thanks!, Austin
    Jul 2014
    Hudson Valley, NY
    13
    I'll have to take some more pics in daylight. That's all I have. Is there a chemical that will help remove the gasket?
    The simplest way to remove the old gasket is with a large screw driver or small putty knife that has been cut down to exactly match the width of the channel the gasket goes in and then scrape it out of there. Even then it is a bit of a pain. Anyway, if you can get the old gasket out and clean up those surfaces there is some life left in the valve. Replacing the whole thing also make sense, it doesn't have all that much longer.
