Results 1 to 13 of 13
Thread: correcting our water from the deluge
    Jun 2014
    Houston, Texas
    475
    OMG. We got 9 inches where I live! Our pool overflowed. We lost power for almost 24 hours. During that time, our pool turned cloudy. We turned the pump back on. Being a first-time pool owner, we don't really know what to do so this is what we Have done so far:
    1. the pumps turned on automatically but they shut off at 7p and power came back on at 6:45p.
    2. i set the timer to run from 7:15 to 6:30 a.m. Our pump Normally runs 7-7 with a higher RPM from 9-4 for our saltwater thing.
    3. I cleaned the skimmer baskets and got all floating debris out.
    4. We started pumping water out.
    Now what? pumps will run all night. Saltwater chlorinator at 7:15 said 3200. I am wondering if that will change by morning.
    19k SW IG
    Wet Edge pebble tech = new 5/16 (replaster)
    Hayward variable speed pump (new 6/17) /Shark for cleaning
    New - filled 10/18/14 - TFP 100 test kit
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: correcting our water from the deluge
    I have a feeling your SWCG will shut down due to low salt. Have back up chlorine ready (bleach).
    Keep the FC level up, test and adjust manually if necessary - don't wait for the SWCG to catch up.
    Vacuum any mess from the bottom of the pool.
    If it doesn't clear in a day or two, SLAM the pool.
    Support the site
    Jun 2014
    Houston, Texas
    475
    I'm sorry, what's FC? free chlorine?
    Husband wants to know if we can use chlorine tabs. We have some that we used before we started the saltwater thing
    OH our chlorinator has a s Super Chlorinate button. Should we use that? If so, for how long????
    I plan on putting the Shark in the pool tomorrow after tonight's/morning storm. I am religious about cleaning that stupid pool. it's killing me that it's so dirty now but there's just no point.
    Last edited by DMS2014; 05-26-2015 at 08:48 PM. Reason: more questions from the hubby
    19k SW IG
    May 2014
    Franklin, NC
    9,184
    FC = Free Chlorine
    Support the site
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Even with a SWG, it's probably not a bad idea to keep a small stash of liquid bleach on hand for emergencies such as this. Try to keep it in a cool, dark place like a closet or utility room so it stays fresh for as long as possible.
    Jun 2014
    Houston, Texas
    475
    please see added Qs above. thanks!
    19k SW IG
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    I would recommend the superchlorinate over the tabs. The tabs are not very slow at adding the chlorine and what you need right now is to get some quick chlorine in there. Bleach would be the chlorine source of choice though.
    Glad to hear y'all are ok. Lots of our TFP folks in Houston area.
    Quote Originally Posted by DMS2014 View Post
    Divin Dave,
    Jun 2014
    Houston, Texas
    475
    I use bleach regularly and I just bought some but I am guessing it won't be enough. it's a small bottle.
    This is our first time dealing with this and the storm was SO out of the ordinary. We made national news. 4th largest city under water. it's really bad here. There's another storm coming in allegedly tomorrow morning early just in time for rush hour!
    how long do we turn the super chlorinate on for??? it doesn't turn off automatically we found out.
    I found the super chlor thing doesn't shut off just this week. I came on here to find out suggestions - we were having our first party and I thought I had read something here about when you have so many people in the pool you should...BUT the site was down! We had our first pool party ever with a bunch of teenagers -- about 20 -- and later that evening the pool was cloudy. I couldn't come here, so we turned on the SC and I thought it would shut off and it didn't! we later tested and everything was fine but I was wondering if we should have SC'd it BEFORE they came or what...
    19k SW IG
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    well you'll need to get some chlorine in the pretty quick so algae cant get hold of it.
    By the way, I agree with BoDarville that by the time you pump teh excess water out, your salt will probably be on the low side.
    Dont put any in though until your SWG tells you the salt is low.
    Im a couple hundred miles north of you. We Only got 5 inches last night. Had to pump my pool out too.
    Crazy el nino year. I never remember so much rain for so long a period of time.
    hopefully the weather man is wrong about more rain for y'all .
    Divin Dave,
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,581
    That "super" chlorinate button is a great marketing tool, but mostly useful if you just wanna bump the FC up a couple of points or so before, during or after a party. In my opinion, other than that, it is too much unnecessary wear and tear on the cell when you can load plain bleach in there and get almost instantaneous results which is what it sounds like you need at the moment.
    Jun 2014
    Houston, Texas
    475
    Quote Originally Posted by woodyp View Post
    We put some bleach in last night and now the storm we were supposed to get is coming through but it is NOTHING like Monday night. Nothing. It took a really long time to lower the pool level it was so high.
    19k SW IG
    jrs_diesel's Avatar
    Aug 2014
    League City, TX
    215
    I feel your pain, mine has topped out twice this year, and almost a third time yesterday. And that's only rainwater that can fall in due to the coping around my pool perimeter. Around 1500 gallons each time it tops out. I've lost a good chunk of my calcium hardness (CH) and cyanuric acid (CYA).
    After a hard/heavy rain I've noticed my pool get slighty cloudy, enough to notice. The few times it has been cloudy, it never registered anything on the combined chloramines (CC) test. All I did was make sure my free chlorine was in the proper range (I manually chlorinate), and the cloudiness was usually gone within a day.
    J.R.
    20K IG gunnite pool
    2HP Hayward single speed pump
    Cartridge filter
    Jun 2014
    Houston, Texas
    475
    Quote Originally Posted by jrs_diesel View Post
    I cleaned the sucker today. Didn't take as long as I thought it would. It's clear. We ran the pumps all night to make up for the hiatus but the SC says 2800. I will take a sample to Leslie's today to see where we are.
    Did not get that much rain today - yay!
    19k SW IG
