Thread: Starting up. Should I add cya now or after slam.
    Aug 2011
    Cochranville, PA
    228
    I finally got around to opening the pool. I drain and refill every year. There is always about 3 inches of gunk I can't get out. I removed all I could and filled. I am slamming now. But my question is, is there an advantage to holding off on the cya until slam is done to save on chlorine because I am slamming at a lower rate. Or is the sun's consumption of the chlorine going to out weigh the savings? I'm in southeast pa full sun. And have no cover.
    1) The size of your pool in gallons 4440.
    2) The type filter you have is an Intex 28651EG Krystal Clear 3000 GPH sand filter
    3) If your pool is an AG (above ground)
    4) Intex 15 by 48 metal frame.
    Southeastern, Pennsylvania.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: Starting up. Should I add cya now or after slam.
    Hi,
    the sunlight will outweigh any savings.
    Bump the CYA up to 30 and you'll be good.
    Divin Dave,
    Aug 2011
    Cochranville, PA
    228
    Adding it now thanks
    Mod Squad pooldv's Avatar
    DFW, TX
    24,493
    From the SLAM directions:
    SLAMing an outdoor pool is most effective when CYA is around 30 to 40. Below 30 you lose too much chlorine to sunlight.*
    Here is the process to SLAM - Shock Level And Maintain your pool. It is important to follow all steps closely. If not, then the SLAM could last for months.
