Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: CYA 99, dumping masive amounts of water. Good idea?
    May 2015
    Memphis, TN
    10
    I was using faulty test strips & ran my CYA way up to 99 PPM. Then I found your forum, had Leslie Pool try to sell me 45 Lbs of water hardener for my vinyl pool at $76 and now I'm trying to figure out your way. I ordered the test kit from the site and I'm attempting to dump half of my pool water to replace it and get better sanitizing from my bleach as well as have the ability to shock if necessary with a lower CYA. Is my thinking sound? Should I shoot for 50 PPM with around 12 hours + of direct sunlight on the water per day?
    21K gal AG 30' round 4' deep. New 1.5 HP Hydrotools pump with very old sand filter. New to pools, new to chemistry.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: CYA 99, dumping masive amounts of water. Good idea?
    Welcome to TFP!!
    While I love your enthusiasm and desire to do it the right way, the tenant of TFP care says that we make recommendations based on accurate test readings. Wait a couple of days and lets see what your testing reveals. I admit, a 99 on pool store testing is usually shorthand for "so darn high we can't test it".
    Give us some test results to base opinions on.
    Support the site
    38,295
    I agree with Tim. Although replacing half the water would not hurt anything ... After you test you may learn that you need to replace more water.
    May 2015
    Memphis, TN
    10
    FC was 4 but I added enough bleach to raise to 10 and I'm awaiting the adequate test kit to test over 5
    TC was 4
    CH 90
    CYA 99
    TA 100
    pH 7.4
    It seems I can assume water exchange is inevitable. Would you agree or should I wait for the test kit? If 100 is the max I can test for I need to add new water just to get a good reading I'm assuming. I was using pucks, powdered shock, & then added 4 lbs of CYA thinking I was still low before I found this web site.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,525
    You are on the right track for sure! Ordering the test kit will help you take over your pool.
    How does your pool look right now?
    Your thinking is sound until you get your test kit. Once you get your kit run the tests and let us know what the results are. There are videos for each test as well.
    Kim
    May 2015
    Memphis, TN
    10
    I'm trying to siphon the water out, but it's pretty slow any suggestions?
    May 2015
    Memphis, TN
    10
    Kim, the pool looks a little cloudy, but good. I just killed off & cleaned up a bunch of algae. Where are the test videos?
    May 2014
    Franklin, NC
    9,184
    Quote Originally Posted by Erickson View Post
    As jason pointed out, and you seem to understand - at least a partial drain & refill is in your future. If you want to now, I would keep it top 1/3 to 1/2.
    Videos are HERE
    Support the site
    38,295
    Siphoning with a vacuum hose and not a water hose would be quicker.
    May 2015
    Memphis, TN
    10
    Is there a way to test CYA over 99?
    38,295
    There is a dilution test you can do that is not all that accurate. See the extended test instructions sticky in the testing forum.
    May 2015
    Memphis, TN
    10
    So, I grabbed an Intex pump from a seasonal pool & dropped it completely into the pool with the return hose over the side wall and ran it for a couple hours last night. I turned it off, turned on my water to fill & went to bed. I got home from work tonight & the water level was where it was when I went to bed last night. Turns out the pump continued to siphon all night & day. guess I'm about back to a complete restart. So, if ever I get a full pool I need to understand what I'm doing.
    Do I fill to my max, run pump for 30 minutes, test chemistry, balance AK, Balance pH, add CYA if needed, then chlorinate?
    38,295
    I do not know what AK is ... I assume you mean TA.
    You should fill, circulate for an hour and then run a full set of test results to figure out what needs to be adjusted.
    May 2015
    Memphis, TN
    10
    Yeah, TA. I'll figure this stuff out eventually. I knew it was wrong, but couldn't remember & just kept typing. Is the order of adjusting levels the most important thing?
    38,295
    Usually chlorine and pH are the most important, but it really depends on the test results.
    May 2015
    Memphis, TN
    10
    Pool Should be full tonight, test kit won't be here till tomorrow night. I can test with a DPD kit tonight, but that'll leave me uncertain of where my CYA ended up. My concern is balancing tonight and still having high CYA tomorrow and needing to dump more. Hard to imagine after so much water loss, but I'm trying to save money. Should I get chlorine to around 5 for the time being & wait on the kit to confirm CYA, or balance everything I can now?
    38,295
    Well, you can not really do much until you now the CYA level. Sure you can raise the FC to 5ppm if you want.
    May 2015
    Memphis, TN
    10
    Better question is:
    Will I run the risk of my fresh water getting contaminated while I wait to test CY?
    38,295
    In a day ... not likely. Go ahead and add 2+ppm of FC.
  20. Back To Top    #20
    May 2015
    Memphis, TN
    10
    CYA 38
    TA 100
    pH 7.5
    FC 5.5
    CC 0
    CH 75
