Results 1 to 9 of 9
Thread: Moving a Hot Tub
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    Moving a Hot Tub
    When moving a hot tub from one location to another, can you sit it on its side to transport without damaging any of the motor and etc...
    Les
    Don't have a pool right now. Just sharing what I have learned over the years!
    Helpful Links:
    Pool School,Pool Calculator,Cl/CYA Shock Chart,TF Test Kit
    Doing BBB and loving it!
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    Re: Moving a Hot Tub
    Depends on the tub. Most are shipped with the equipment end down. Some manufacturers also mount 2x4's to the frame of the tub to create a foot for it to stand on. If you take the front panel off there may be some sturdy posts that you can screw a frame into and then flip it up onto that. You won't damage the equipment if it is securely held in place. If the pumps are mounted to rotten wood then go ahead and remove them first.
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    This is one we may be getting from someone. The say everything woks just the top is in bad shape so we are assuming that is the cover
    Les
    Helpful Links:
    meatloaf's Avatar
    Feb 2008
    Gilbert AZ
    373
    I got mine about 11/2 years ago, also used. Mine was moved by dolly on it's side but laid flat on the truck. I had professional hot tub movers do the moving. They did have me sign a wavier not holding them responsible if it fell apart.
    My pool is a 10,500 gallon (420 Sq Ft ) kidney shape. STA-RITE HRPB30, Sand filter 30" 98 GPM, 1 HP Maxi-Glas 2 pump, BBB Method, Taylor K-2005 test kit, 50 Watt 12V low-voltage pond light illuminates the pool at night for a nice soft glow.
    Rocklin, Ca
    467
    Mine was shipped flat and was rolled on a piano type dolly into the backyard on it's side. The job was done by three large Samoan's who were very good at their job. My tub is an 8" foot one and weighs just over 1000 lbs empty.
    I have photos of the job in progress if you're interested.
    11000 Gals, Intelliflo, Sta-Rite Cartridge, Polaris 360
    Pool I built in my old house: my-new-pool-build-t4534.html
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    Sure! I would love to see the pictures. I didnt realize that a hot tub was that heavy
    Les
    Helpful Links:
    Rocklin, Ca
    467
    I'm at work now. I'll post them up later tonight.
    Rocklin, Ca
    467
    After looking at them I realize I don't have any of them actually moving it on the piano dolly. I hope what I do have is helpfull. The actual rolling of the tub on the dolly wasn't very exciting which is probably why I didn't take any pictures
    Notice that they used a piece of wood at the bottom pivot point that spans the entire width. I would guess that this spreads the load of the tub across the whole tub edge as they tip it down.
    All of these guys were big Somoans that were at least 250# and obviously were good at moving spas. I always enjoy watching people who are good at what they do, even if it's something like moving a spa.
    launboy's Avatar
    Jun 2008
    S.E. Wisconsin
    582
    We just moved a spa actually. Got it used and it was already mostly apart. The spa pack(pump and heater) were removed and the skirt was taken off.
    We rented a u-Haul trailer (5'x9') for the 6' x 7.5' spa. We flipped it upside down and set one side of the top of it in the trailer, and leaned the other side against the top railing. Drove 20 miles home this way with no damage to the tub. I'd say the spa is 300-400 lbs without skirt or pump.
    HTH,
    Adam
    18' x 42" Intex Easyset Pool, with 16' x 52" deep end in the middle. Approx. 5500 Gal.
    Hayward Power-Flo LX 1 HP, 100# Jacuzzi Brand Sand Filter(Piped underground so it looks nice) 8)
    3 - 2' x 20' Solar Pool Heater Panels(roof mounted)
    Goin' on 9 summers...NOBODY thought it would last this long.
    Buried Portable Spa sharing pumps and water with pool (Almost complete project)
