Thread: Pump speed matters
    tcat's Avatar
    May 2012
    Austin, TX
    731
    Pump speed matters
    This has probably been mentioned but thought I'd confirm. If you have a 2 speed or variable pump you should check your chemicals on high. I just checked my fc on low, fc 3.5, cc 1. Turned to high for 30 minutes, rechecked, fc 4.5, cc way less than .5. A lot to be said for agitation! Had an algae fright.
    IG pebble, 15,000 gallon
    48 PentAir DE Filter with backwash valve
    PentAir Whisperflo pump with 1hp 2-speed motor
    Aquabot 4WD, Poolskim
    Intermatic Dual Timeclock with freezeguard
    DIY chlorine feed
    BBB
    Re: Pump speed matters
    Most of the time, having the pump running for half an hour before testing will take care of things, even if it is on low speed.
    tcat's Avatar
    May 2012
    Austin, TX
    731
    What I thought, but been running on low for 7 hours. Checked from same spot. I do have my jets aimed towards edge/surface to rotate flow circularly towards skimmer. Aiming down would probably circulate better.
    DIY chlorine feed
    BBB
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Do you have a floor drain?
    tcat's Avatar
    May 2012
    Austin, TX
    731
    Two of them.
    DIY chlorine feed
    BBB
