Thread: No Flow
    May 2015
    Miami, Fl
    47
    No Flow
    Is it normal to get a no flow reading on the SWG every now and again, then goes to flow?
    Built March 2015 13000 gallon free form exposed aggregate with sheer descent, Jandy 2HP VSP, Jandy 1400 SWG with Aqualink PDA and AquaCal electrical heater. Pentair Clean and Clear filter 150SF. TF100 test kit. Pentair Kreepy Krualy Great White.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: No Flow
    No. Not normal. What brand?
    May 2015
    Miami, Fl
    47
    Re: No Flow
    Jandy Aquapure 1400. It did it earlier today with a clean filter and running pump at 1800 rpm which is more than required by Jandy after a call to them. If it's not normal the unit is still under warranty and would be to notify the builder.
    Apr 2011
    Murrieta, CA
    2,360
    Re: No Flow
    Could be loose wire or switch going.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,516
    Re: No Flow
    I had that issue with mine when running my VSpump at 900 rpm. As the filter clogged up I would get low flow error sometimes. Bumped it to 1100 rpm and problem solved.
