Thread: question on valves going from pool to spa and back ?
    Houston, TX
    1,094
    I am a new pool owner and have not had the time to read up on how to use the Hayward ProLogic PS-8 controller.
    Our panel is configured for pool or spa operations w heater, blower, etc.
    I have an AquaPod Remote, and was trying to sync-up the remote w the panel. So if I press the BLOWER on the panel, I was trying to identify what function on the Remote lit-up so I would know what function key to hit on the remote to turn on the BLOWER. When I was at the panel and I went from POOL to SPA, I saw the valve's change at the equip pad to SPA from POOL and vice versa. However, I did not see the blower identified on the AquaPod. Is there a way to sync-up the names on the panel to the names on the AquaPod for all functions?
    For example, POOL, SPA & FILTER are synced-up. So are the SCUPPERS in the POOL mode and are labeled WATER FEATURE on the AquaPod. We also have firebowls that are labeled GAS FEATURE on the Panel, but AUX 4 on the remote AquaPod. Is there a way to convert the AUX 4 on the Remote to FireBowls? And need to give the Spa BLOWER a name on the remote as well.
    THank you very much,
    tstex
    38,251
    Re: question on valves going from pool to spa and back ?
    Sounds like you should read up the manuals on the ProLogic and the Remote ... that is what I would have to do to try to answer your questions
