Thread: intex liner leak
    May 2014
    nutley,nj
    7
    intex liner leak
    So I spent 6 hours setting up my ultra frame pool for its second season and when I started filling I noticed some water around the edges, so I got in to see whats up and of course found a very tiny hole on he bottom of the liner so I stop filling with water. I bought a patch kit but my question is should I keep filling then patch it or drain the water that's in it and patch it with the liner dry?
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: intex liner leak
    If it is a vinyl pool patch kit you should be able to do it with water in it. It is recomended you do a layer effect. Patch, then add anothe patch on top of it.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
