Results 1 to 15 of 15
Thread: Stenner recommendation.
    Hello all. Looking to put in a Stenner to help automate chlorination. I am working a lot and want to make sure the pool stays nice and sanitary. Also, sick of pucks and constant CYA issues due to a small pool. So after a bit of research on this site, I've come up with this idea. I just want to run it by someone who has done it before and make sure I haven't missed anything. So I'm looking at Stenner Econ T series with built in timer. For options I am going to pick 8.5 gallons per day. Was a bit unsure about this but assuming I run pump for 6 hours minimum that would be up to 1.25 gallons per day, which should be more than enough. Agreed? Add on the 15 gallon tank which is will be mounted to. I was going to have it flow into the top part of my old in-line puck tube as some others have done. And it will be plugged into a gfci outlet which is already right there. Tell me your thoughts please. Thanks for your time.
    I had considered a SWG but to be honest, I'm not the handiest of guys and the maintenance /installationseems like it may be a bit high.
    10k gallon in ground gunite pool. Cartridge filter. Gas heater. Sunny New Mexico.
    Re: Stenner recommendation.
    You absolutely do not want it running into a puck feeder. That is an extremely bad idea, with the potential for causing an explosion.
    Other than that, everything sounds reasonably good.
    I would get one with a slightly higher flow rate. 6 hours is a lot of time to run the pump, most than most pools need. You wouldn't want the Stenner forcing you to continue running the pump for extra time should you change your mind about how much pump run time you need.
    So this setup isn't safe? Maybe I said it wrong?
    New Stenner Convert
    Definitely not.
    What would you recommend? Can I just tap into the line before the feeder? I will not be using pucks in there at all. Was that the unsafe part?
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Quote Originally Posted by PeterChevalier View Post
    Mixing the chlorine in the chamber that used to hod the pucks. I would either tap the pipe as the last item (after the feeder) before it returns to the pool or cut and insert a "T" as the last item.
    Support the site
    Cool. Thanks Jason for the recommendation on the bigger input tube. Can see how that could save a big headache in the future. And thanks Tim for the clarification on the tube. Not a whole lot of room after the tube, so maybe I'll just take it out and use that space for an injection point. So bear with the rookie question here. But assuming this is where I cut out the puck feeder, just get a T piece and inject on top where the arrow is?
    May 2014
    Franklin, NC
    9,184
    Exactly. Here is a link to my Stenner Pump install with photos
    Support the site
    Very nice. I hope mine will look that good!
    Ok. Ordered the Stenner with timer and uv tank. Here's a plumbing question someone may be able to help with. Where I cut out the puck feeder and put the T in, what's the best way to attach the chlorine hose to the T? Is it possible to make it so I can remove the tube in the winter while still keeping a sealed system? What do you think the best way to go about that would be?
    May 2014
    Franklin, NC
    9,184
    I used a "T" that is slip/glue on the two ends and threaded on the small leg. If needed, you can unscrew the injection point and screw in a plug.
    Support the site
    Cool. Is that t piece something you found locally at a store or did you have to order it?
    May 2014
    Franklin, NC
    9,184
    Lowes has them in the plumbing isle.
    Support the site
    Jul 2013
    Dallas, TX
    12
    The Amazon price is high, but this is what you need. I think they are about $3 at Lowes and Home Depot.
    http://www.amazon.com/gp/product/B00...ilpage_o01_s00
    17K gallon IG Plaster. 48sqft Hayward DE filter. Stenner Pump
    Mar 2015
    Sugar Land , TX
    424
    I just used a drill and tap that I purchased at HD. All of about 5 minutes work. Injecter screws in the new taped hole. The instructions on your Stenner pump will tell you what size. 1/4" I think it was
    8500 gallon IG Pebble Sheen with Spa. 3hp Pentair VS Intelliflo ( pool ), 3/4 hp WhisperFlo ( water feature ),Pentair Racer, 400K Pentair heater, Pentair 500sqft Cartridge filter, EasyTouch 8, Stenner 45mp2 15gallon wired to ET8
