Results 1 to 8 of 8
Thread: Kreepy staying afloat rather than down
    Jun 2013
    Bay Area, Calif
    18
    Would much appreciate some input. I've recently noticed my Kreep Krauly is remaining afloat and off-kilter rather than staying suctioned to the plaster. Usually it moves around alright, but today, it's slowed down quite a bit, as well as staying afloat...
    I've taken some pictures and a short clip to show the condition of the Kreepy -- it's only ~2 years old. The pool is 25,000 gallons, DE filter with solar panels. Pressure seems fine, ~5-10 psi when bypassing roof panels, ~15 if going through panels. Attached to 3' hoses to the skimmer with a regulator valve with 3 weights as suggested by the manufacturer -- ~5 inches, ~5-6 feet, and ~10 feet.
    I don't see anything cracked, and the flapper/hammer seems to be moving fine inside the body, nor debris caught in the body...
    Youtube video/pictures
    Any tips appreciated!
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    Re: Kreepy staying afloat rather than down
    Check that your pressure regulator slide moves up and down freely and that the internal spring returns the slide to it's fully closed position. It's common to have leaves and stems jam the slide up, preventing the full suction of the pump from getting to the Kreepy. There's a few other things it could be but check the regulator first.
    21K gal 16' x 40' in-ground pool built 1959, old school with Jacuzzi bronze pump, American Products 24" Sand Filter & Americana Multiport valve, Jandy Lite2 millivolt heater, Coverstar cover, and classic Kreepy Krauly.
    Jun 2013
    Bay Area, Calif
    18
    Quote Originally Posted by gtemkin View Post
    Thanks for the tip.
    Fortunately the valve is clear and slides well.
    Played around with the hoses and none seem to be cracked or suctioning/pulling on air if I pull them out one by one with the pump running...
    Dec 2014
    Riverside California
    482
    Inspect the Pleated Seal and the Foot Pad for wear. My Kreepy was doing all kinds of bad things, and upon replacing these items, it works good a new now.
    38000 Gal, IG, Plaster, 20' x 40' x 10', Attached Raised Spa, Intelliflo VS 3 HP (011018), Pentair Quad DE 60 Filter, Raypak (Rheem) 400,000 BTU (407a low Nox), Easy Touch 8 upgrade, Screenlogic 2 with wireless, IS-4 Spa Side Remote, Stenner 45MPHP10 w/15 gal tank, Intellibrite 5g (3), Dolphin Triton Plus robot with PRO remote, Water Tech Catfish handheld vacuum for spa, TF100 with SpeedStir.
    Jun 2013
    Bay Area, Calif
    18
    Quote Originally Posted by gary300 View Post
    Please see pictures at Youtube link:
    Just took a look and both are fine, no cracks, fixed in place fine
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    ....another thing to check is that the swivel bearing where the hose attaches the the body is not binding. That can cause off kilter operation because the hose will be twisting the KK at various times as it's circulating around.
    Jun 2013
    Bay Area, Calif
    18
    Thanks for the advice, I'm able to spin/turn the swivel cone, but it doesn't seem to have much lateral/sideways give -- here's a video, uncertain if this is normal operations?
    Kreepy swivel cone and bearing
    Here's one snapshot from the video
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    I think that's fine as long as it spins. Not sure what else to recommend. May want to play with your weights some more. I know I've had to move more weight closer to the KK than the manual suggests. Not sure what kind of online/phone support KK has.
