Thread: Main drain possible leak
    andyrob2215's Avatar
    May 2014
    Portage, Indiana
    127
    Hey guys
    I havnt been able to find a forum relating to this specific issue I may be having. I have a 21' x 52" dual main drain agp. In going to be installing a new liner this Thursday (hopefully) I have no water in the pool at this time and the old liner is almost all removed. Over the winter, the water level dropped and shredded the liner. At first I thought it was the liner leaking but now I'm beginning to think it was the main drain that cracked. Is there a way without hiring a plumber with a scope to check to see if there is a leak? Either with water/air pressure or plugging the main drains something of that nature.
    Thanks for any help
    21'x52 AGP 11200 Gal
    TFPC Method
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Main drain possible leak
    If you are going to replace the liner, I would just ditch the MD. It is pretty much useless and will only cause problems like this.
    Mark
    May 2014
    Portage, Indiana
    127
    Well, I borrowed a scope and it all checked out. Got the new liner in today and the pool is half full. I actually love the main drain and how clean it keeps the pool.
    TFPC Method
