Thread: do not have permission to access Further Reading
    Mod Squad pooldv's Avatar
    DFW, TX
    24,484
    Howdy,
    Trying to get to Further Reading from pool school
    Trouble Free Pool
    And got this error
    pooldv, you do not have permission to access this page. This could be due to one of several reasons:
    Your user account may not have sufficient privileges to access this page. Are you trying to edit someone else's post, access administrative features or some other privileged system?
    If you are trying to post, the administrator may have disabled your account, or it may be awaiting activation.
    I'm hoping ya'll are working on broken links, but just in case ...
    38,272
    Re: do not have permission to access Further Reading
    This is a known issue ... all the links got messed up with the software change so instead of getting a list of broken links, I thought you would just get a blank page, but apparently you get an error.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    uh oh!
    You're in trouble now!
    Quote Originally Posted by pooldv View Post
    Howdy,
    Trouble Free Pool
    And got this error
    Divin Dave,
    DFW, TX
    24,484
    Quote Originally Posted by Divin Dave View Post
    uh oh!
    I knew I was going to get banned after I told someone to raise their CYA up to 300!
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,085
    Just an FYI on this.....I took this article down as 100% of the links were broke after the server swap. I'm going in and manually editing each link so that it's all current and updated. At this point I'm about 1/2 way done with this task. It will return very shortly.
