Thread: air release on DE filter
    swirlywater's Avatar
    Feb 2015
    columbia station / OH
    63
    I let someone vacuum my pool the other day, and they pulled it out without disconnecting it from the skimmer first. I noticed rather quickly because I heard a strange noise from the pump. I proceeded to re-start the system as if it was the first time for the year. The weird thing is now, if I open the pressure relief valve on the filter, no water or air spray from it. I backwashed the system thinking maybe the air that was sucked in did something to my grids. My pressure is back to normal, and my pool seems to be in good working order, but if I open the pressure relief valve, nothing happens. Should I be concerned?
    20x40 30k gal vinyl, Inline Tri-Chlor Chlorinator, Hayward 250K btu heater, Hayward 2HP Super Pump, Hayward DE6020 Filter,
    Feb 2015
    63
    May 2014
    next to my pool
    3
    Re: air release on DE filter
    I am no expert but this happened to me as well. Something clogged the tiny hole on the pressure relief valve and is stuck there.
    You can try to open the valve with the pump off, and assuming the pressure-relief valve is being the highest point of your plumbing, will suck in air due to gravity. This may unclog the valve. If this does not work, you will need to take the valve apart and get the debris out that way.
    38,271
    Sounds like the air release valve must be clogged because with the pump running and water going through the filter (not on Waste or Recirculate right?) air/water must come out.
    Try opening it with the pump off as see if air is sucked in ... might dislodge the blockage ... or try shooting a hose into it (with the pump off) ... or you may have to take the lid of to clean it out.
    30,415
    Air or water should come out....are you saying neither?
    Feb 2015
    63
    Thanks guys. Yea, so when I was first restarting the system air, then a little water, and a little DE. Now it just drips a little water. I will try your tips when I get home today.
