Thread: My pool is a swamp
    Jul 2014
    MOUNT MORRIS
    8
    My pool is a swamp
    My husband usually tends to the pool by taking a sample to the pool store and spending way too much money on their recommendations. I told him I want to try the BBB method this year. We are just getting this up and running and I wonder if I should drain as much of the swampy water our first and refill it or just add fresh water to what is there and try to combat all the algea.
    PLEASE HELP!!
    Sandy
    16 x 40 36,000 gal., IG, Vinyl, Sand Filter, TF 100 test kit. age (bought the house in 2012 with pool there, I believe it was 8 years old), Michigan
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: My pool is a swamp
    Welcome to TFP!!
    Our general rule of thumb is that 5,000 gallon pools are the upper limit of drain and refill to fix it.
    We really try to down play the BBB name, because too many folks were running out and stocking up on the B's when they didn't need to.
    If youa re going to follow our methods you will need one of the recommended test kits. You can buy a kit at a pool store, but again the pool store kits generally won't cut it. To effectively practice the TFPC methods, the FAS/DPD chlorine test is essential. All these kits contain that test while very few other kits do. Think of it this way, do you see a doctor blindly prescribing drugs without seeing the patient or having tests run? Here at TFP we are going to ask for photos so we can see the condition of the water and are going to ask for a full set of test results. I recommend the TF-100 because it comes with more of the stuff you use every day. Ge tthe XL option, because you are going to need the extra to clear the swamp.
    Order your test kit and we can worry about the best course of action after we have test results.
    While you wait you can do a little reading. Start with these:
    ABCs of Water Chemistry
    Recommended Pool Chemicals
    How to Chlorinate Your Pool
    Support the site
    Jun 2014
    15,103
    Hi Sandy. Welcome to TFP. The first thing you really must do .... order one of the recommended test kits (see my signature link). You MUST have a good test kit of your own. Do NOT reply on the pool stores or test strips, they will steer you in the wrong direction.
    robdac's Avatar
    Jun 2014
    Weston, FL
    232
    Sandy, if you follow the methods here you're going to save a lot of money and make your husband a very happy man! You'll save a lot of frustration in the process. The pool store isn't going to like you a lot however! Get a recommended test kit and head over to pool school.
    11K gal IG screened-in plaster pool w/ spa
    pentair 150 cartridge filter, Pentair Intelliflow VS pump,
    Aquarite AQR15 SWG, AquaCal Heatwave Heat Pump, TF-100 test kit
    smforte's Avatar
    Sep 2013
    Montgomery,Al
    668
    And I highly recommend the speedstir.... Makes testing so much easier instead of having to swirl the test by hand.
    Montgomery, AL
    27000 16 x 36 IG, Vinyl, Grecian, Hayward Sand filter, 1 HP Pentair whisperflo motor, Aqua Genie filter not by choice, no extra jets, Dolphin s300i robotic cleaner,Taylor K 2006 test kit, speed-stir which I couldn't live without!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Welcome to TFP!
    Plus one one on getting one of the Recommended Test Kits, I use the TF100 from tftestkits.net. XL option and speed stir are great ideas.
    When you get it give us some test results and get ready to SLAM Your Pool. The more you scoop out the debris the less bleach you will use and the more you brush the faster you will kill the algae.
    Here are some of my fave Pool School articles in case you missed any of them.
    TFPC for Beginners
    ABC's of Pool Water Chemistry
    Here are the Recommended Levels for your pool.
    Here is the Water Balance for a saltwater pool.
    Here are the Recommended Pool Chemicals and how to add them.
    Use PoolMath to figure out how much to add.
