Thread: Pool Cover Is Shot
    May 2015
    Roaring Brook Township, PA
    1
    Pool Cover Is Shot
    HELP! My above ground pool cover has several small holes in it. This is most likely a result of the horrible winter we had in the Northeast. Lots of snow, ice, small branches, etc. I started to drain what I thought was the cover but discovered that I was actually draining the pool. There is about a ton of wet leaves on the cover. My question is how to remove the cover with out the disgusting leaf rot falling into the pool since I can not drain the cover. I am attempting to back fill the pool under the cover and simply float it off when the water reaches the height of the rail (I have secured the skimmer with an Aqua Door). Any other thoughts on this mess?
    GOT THREE KIDS
    Re: Pool Cover Is Shot
    Welcome to TFP!
    You should be able to setup a syphon to get most of the water off the cover.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Welcome to the Forum GTK!
    Enjoy your time on TFP.
    Essential Links:
    JoeSelf's Avatar
    Jun 2014
    Glassboro NJ
    333
    Keep one side attached where you will be pulling cover off pool. ( I have clips to help me keep my cover in place all winter). Drag cover along with the pillow towards where you will be dumping. I tie a rope thru several holes at the far end of the cover. (If you don't have a pillow you could slid a float under the cover with rope. This really helps in keeping the cover out of the water and the junk out of the pool.) Pull the cover, pillow & junk on the cover towards you SLOWLY. Keep the siphon going the entire time. Not a fast process. I gather the cover up at the far end and then pull the whole thing off keeping the cover clipped to the rail. Note: you will get wet and dirty. Old clothes and shoes.. The rope on the opposite end is the key to not letting any thing get out. I unclip one clip at a time on each side of the pool.
    13700 gal, 32'x16'x54" AG oval, vinyl, Echo Canyon II, 8500 series, Narrow Yard, Safety Fence & Stair, Sta-Rite Crystal Flow T-210WF, 44 GPM, Hayward SP1580TL 1HP Pump, Aqua Luminator, Festiva wedding cake steps, March 2006, TFT-100, Speed-Stir, Sample Sizer. Avatar Credit: TJ Townsend
