Thread: How are these numbers looking? I'm high salt, low CYA, high chlorine, hmmm..
    Jun 2014
    Roseville, CA
    343
    CL 5.5
    CC 0
    PH 7.4
    TA 90
    CH 350
    CYA 40
    Salt 4200
    Borate 50
    CSI -.43
    I raised TA using Baking soda, and that seemed to get my CH up there beyond where I feel I should be.
    Regarding chlorine, I have my SWG set at 20% and it's a struggle to keep it down. It's almost always at 6, probably to do with high salt, plus the SWG runs when the solar water panels are activated. Either way, my CYA is low. Do I need to raise my CYA?
    Or should I leave well enough alone. Dilution is not really and option, due to water restrictions and our drought here in California. Swim season is just beginning so not a lot of splash out.
    I tested using my new K-2006 kit.
    Thanks in advance..
    SWG: CircuPool (5/2018) Universal 40; 3000ppm seems ideal;
    My Ideal Specs:
    FC 5; PH 7.4-7.6; TA 90; CH 350; CYA 75; = SI ~ 0.19
    14,000 gal, in ground, plaster, Cartridge filter, Borates
    TAYLOR K - 2006 Last Circupool SI30+ 4 years RIP.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: How are these numbers looking? I'm high salt, low CYA, high chlorine, hmmm..
    Since you have a SWG, yes you need to raise Cya to 70-80.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Aside from CYA, everything looks fairly good. Raise the CYA up, and turn down the SWG percentage and things should come out just right.
    Jun 2014
    Roseville, CA
    343
    OK, will do...
    Thanks for the advice!
    My Ideal Specs:
