Thread: opening time - water replacement
    May 2011
    Los Angeles, CA
    228
    Hello everyone!
    Time to open is nearing and last season I closed with the following results:
    CYA 50
    TA 70
    pH 7.4
    CH 790
    TEMP 58F
    FC 10
    CC 0
    I would like to change some water at opening to bring down the CH.
    Does anyone know if you need a permit to do so in Los Angeles, CA area especially due to the drought?
    Thanks!
    Suley, West Hills, CA
    IG 23000 Gallons with IG Spa Gunite plaster, Pentair Intelliflo VS 3HP, Pentair Clean & Clear Plus 420 Cartridge filter, Teledyne Laars One series 400,000 BTU Nat Gas Heater, Hayward Max Flo 1HP Single Speed Spa pump, Noisy Spa blower, Dolphin Deluxe 4 robotic vacuum.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: opening time - water replacement
    No idea, but welcome back!
    We have some CA pool owners here, so hopefully they will weigh in.
    Essential Links:
    May 2011
    Los Angeles, CA
    228
    Thanks! I was in lurk mode...
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Hello Suley,
    You can run your pool with CH that high. You'll just have to control/run lower your PH.
    May 2011
    Los Angeles, CA
    228
    Thanks! But the water was tasting a bit salty last year too.
    Anything I can do to reduce the taste?
    Apr 2011
    Murrieta, CA
    2,360
    Don't drink pool water. sorry couldn't resist.
