Results 1 to 7 of 7
Thread: Help identifying old equipment, 1970's
    Aug 2010
    Lake Jackson, TX
    130
    Hi all,
    I need some help identifying this old sand filter and the multiport valve. The label on the filter is obliterated and the tags on the multiport are difficult to read.
    I'm trying to figure out how to open the filter for a deep clean (we are in the middle of a SLAM) without breaking anything.
    I'm not as familiar with sand filter efficiency so I'm not sure how quick to expect it to filter the green goo. The pressure is running at 20 but doesn't seem to be climbing as expected. Also the green seems to taking longer to fade than anticipated.
    Thanks for the help.
    25000 gal IG gunite plaster. Built in spa, built 1984.
    48 SF Hayward DE-4800 filter
    1 hp Hayward super pump
    3/4 hp Polaris PB-4 booster pump, Polaris 380
    Taylor K-2006 test kit
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Help identifying old equipment, 1970's
    The filter may well need a deep clean and it can't hurt. The top should simply unscrew from the top of the filter body.
    With that out of the way, the filter will not get rid of the green. That is a job for Free Chlorine, and until you get it high enough for long enough the green will remain, and or get worse. If you have a proper kit, follow SLAM procedure to the letter and it will clear.
    Essential Links:
    Aug 2010
    Lake Jackson, TX
    130
    Thanks Patrick_B, I do have a proper kit (Taylor k-2006) and the SLAM is in progress. I'll try the unscrewing I'm just afraid of breaking it since it's old and plastic.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    I hear you there.
    Let's keep any more chemical/treatment questions over in the other thread about erratic readings, and call this one done. The green pool pictures would be nice in that one BTW.
    Essential Links:
    Aug 2010
    Lake Jackson, TX
    130
    will do.
    Mar 2011
    441
    The filter looks like a Purex/Trition tr60 which is now a pentair tr-60. A very common filter.
    20X40 30,000 gallon gunite pool
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    This article complete with pics might help you with that sand filter, Deep Cleaning a Sand Filter
