Results 1 to 12 of 12
Thread: our AGP nearing completion
    Here it is. Decking is nearly complete, will add pics when done.
    The solar is to be connected soon. Cheers
    [attachment=1:i0z00dlb]pool.jpg[/attachment:i0z00dlb]
    [attachment=0:i0z00dlb]pool1.jpg[/attachment:i0z00dlb]
    38500lt AGP, hayward 500cf cart. filter, 2 x ozonics mark 6 ozone generators, automatic liquid chlorinator, solar controller, 2 x LED lights, hayward pool vac ultra, 3/4hp Onga pantera pump.
    Firefly2000's Avatar
    Jul 2008
    Sydney, Australia
    38
    Re: our AGP nearing completion
    Looking good! It will soon be worth the wait, and just in time for summer!
    Good to see another Aussie on the forum. (I thought the pictures looked very much like an Australian landscape!)
    Daniel
    47000L (12500 gal)
    IG Quartzon Interior
    Rolachem Acid & Chlorine dosing
    Paramount In-floor cleaner
    1.5HP pump + Sand filter
    Solar heating under the great Aussie sun!
    DaveNJ's Avatar
    Toms River, NJ
    520
    Nice job. Large and impressive deck.
    IG 18x36 oval vinyl, Spill over spa, Northstar 2hp-2spd, 2.5" piping, S310T 500lb Sand filter, 400k gas heater, AutoPilot SWCG
    http://www.tftestkits.net/
    amjohn's Avatar
    Jul 2008
    Rural NE Texas
    389
    What kind of solar are you using? Manufacturer, type, size, erc?
    Quite a deck!
    28 ft round Doughboy Sand Dollar II AGP, Aug 2008: 4 ft shallow, 6ft deep end: 24K gal approx Hayward Power-Flo Matrix
    1&1/2-HP 2-SPD Pump, Hayward 27-Inch Sand Filter with a little DE -(2) 4ftx20ft Solar Bear AGP Panels w/ Goldline auto-controller, 50ppm Borates And some day, maybe this year, a DECK!!!
    Thanks a lot people.
    The deck is about 90 sq metres. $$
    amjohn:
    the pool doesn't have its own power supply.
    We are on solar/wind power here (not connected to grid)
    We added to the solar system to cope with running the extra power load (the panels you see in pic 175w each), now we have about 3.5kW of solar with a wind generator capable of 1Kw, and a battery capacity of 1100 amp/hrs.
    The system is 48volt with a 48 to 240 volt 3500w inverter/charger/booster (Xantrex model)
    Butterfly's Avatar
    South Carolina
    10,045
    Really looking good!
    Quote Originally Posted by RaMpAgE
    Now that's amazing! 8)
    You're done SLAMing when:
    Crazycalvin's Avatar
    Mar 2008
    Irmo, South Carolina
    56
    Wow! That is going to be sweet! Later, calvin.
    15 x 26 Sharkline
    2.5 HP Dual Speed Pump
    200 Sq. Ft. cartridge filter
    Decking complete, now working on a shade sail and fencing, we have had a few swims now and the water is at 26' C at the moment.
    Cheers
    Casey's Avatar
    SW PA
    10,448
    Very nice!
    Any chance we can get a water shot and see the liner?
    Quote Originally Posted by Casey
    Very nice!
    sure can, standby
    1.2m - 1.8m deep end
    8.8 x 4.8 x 3.8m keyhole
    pH 7.5
    TA 140
    CH 150
    FC 0.8
    CC 0.0
    CYA 25
    Casey's Avatar
    SW PA
    10,448
    That is one blue liner! 8)
    I like it and thanks for posting! Oh and I didn't know you could get key-shaped above ground pools! Must be an Aussie thing!
