Thread: Pool Circulation???
    whataboy's Avatar
    Jan 2015
    Lewisville,Texas
    53
    Pool Circulation???
    New pool owner for only 6 months now. Here is pic of my pool showing skimmer locations (2) and (4) returns with clockwise circular pattern. It seems to be doing good job with water just breaking the surface. Is this the correct way? Thanks
    Rick T.
    12,000 gallon IG Kidney shape,gunite,white plaster w/25% blue quartz (Chlorine)
    Jandy LED Multi-color pool light, ,Pentair VS Pump,Pentair FNS 48 DE Filter,Polaris 280 Cleaner
    TF-100 test kit, Taylor K-2006 test kit, Speed Stir, BBB Method, PoolMath, TFPC
    Re: Pool Circulation???
    Hi whataboy... To me the circulation seems fine. Do you have a main drain at the bottom as well? If I may ask, what is in the floater? Very nice pool, BTW.
    14,000 Gal IG Pool/500 Gal Attached Spa
    Pentair Whisperflow 1hp Single Speed Pump
    Sta-Rite Posi-Flo PTM-135 Cartridge Filter
    Hayward H400 Natural Gas Heater
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Looks good to me. It doesn't have to break the surface if you don't want it to.
    whataboy's Avatar
    Jan 2015
    Lewisville,Texas
    53
    Yes I do have a main drain at deep end in the center. Ha the blue floaty thing has since been thrown away. For some reason the wife keeps throwing it in so I took it upon myself to toss it in the trash. Its not needed with BBB method..lol
    Rick T.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Quote Originally Posted by whataboy View Post
    Good answer! and Nice Pool!
    Yes, that circulation pattern is fine. It really depends on prevailing winds and if the circulation is carry floating debris to the skimmers. If it isn't then try switching to counterclockwise.
    No need for the returns to ripple the surface unless you are trying to raise PH or cool the pool.
