Thread: Pool Set...Intex...
    MirellaJoe's Avatar
    Jun 2013
    Aurora, Ontario-Canada
    125
    Pool Set...Intex...
    Pool is set up, all chemicals balances are perfect thanks to my test kit i order last year, all i Need now is heat!! I hope it's gonna be a hot summer i'm still on the fence about heating up the pool, if i should go gas since it's taken down each fall. What are u guys doing this year to heat ur intex pools?
    Intex Ultra Frame 16'x48" sand filter w/intex SWG.
    Pool Blaster Max Vacuum
    3rd year with Intex and no problems
    Pentair Mastertemp BTU 125/ propane
    Taylor K2006 Complete FAS-DPD
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Pool Set...Intex...
    I just use my solar cover to heat mine.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    MirellaJoe's Avatar
    Jun 2013
    125
    I also have a solar heater but doesnt seem to do much honestly, it would work better if it would stay hot and sunny everyday all day
    Orlando, FL
    690
    I used solar when I had one. Now, I use more solar.
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
    Jul 2014
    Oakbank, Canada
    389
    I have 2 sets of 4'x 20' solar panels, double from last year. Have not finished hooking them up yet though.
    Ultra 16', Intex Sand filter/pump combo, 8' x 20' solar panels, solar blanket w/roll tube, 1" extruded foam floor with Gorilla pad, Liquid chlorine and stabilizer.
