Thread: Inlet leak, Gaskets not forgiving enough
    Hi All,
    My return inlet is leaking by the gaskets and leaking down the outside of the pool.
    Just did a liner and skimmer and new inlet.
    I noticed when installing the inlet (under water) that the hole drilled in the side of the pool created a ripple
    in the metal where the rubber gaskets sit.
    I tried 2 rubber gaskets inside and 1 outside but it still leaks.
    Do they make a gasket type material like plumbers putty that I can roll in my hands
    then apply to inlet and re-install.
    I see the epoxy type compound but concerned of its effects on the liner.
    Thanks
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Inlet leak, Gaskets not forgiving enough
    Welcome to TFP! Sorry about the leak. My guess is that because of the ripple in the metal that the gasket cannot sit flush with the side. You may have to try to get the ripple out.
    Can you post a pic. Upload to photobucket, then copy the IMG code and paste it here.
    Can you also update your location and signature with pool and equipment info in settings?
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    May 2012
    Montville NJ
    545
    Leslies pools sells pool lube in a tube. I put that on all of my gaskets.
    -dave
    27' Round ABG (17,000 gal) - +/- 11 hours of full sun per day
    Hard plumbed Hayward Perflex EC-40 DE filter w/ 1 HP pump (Got a new one June 2015)
    Filered 4 hours per day (on a timer)
    Pentair Aqualuminator - now working - and now dead once again, this time for good.
    Zodiac Wahoo
