Thread: Jandy lite 2 problem
    May 2015
    NEW YORK
    2
    I wonder if anyone could solve my problem. I was running the heater for @2 hours when it started smoking. I opened up the front panel and the wire to the fusible link was burnt along with my control display. It was extremely hot inside the panel, you couldn't even touch the gas pipe it was so hot. I am in the process of replacing the control panel but want to prevent this from happening again. Any ideas of what could have happened???
    DAN MCCANN
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Jandy lite 2 problem
    Welcome to the forum Dan,
    I have no idea, but that needs to be sorted by a pro ASAP in my opinion.
    Essential Links:
    ps0303's Avatar
    Jul 2011
    FL
    3,711
    You could have a clogged burner tube or the heat exchanger is clogged up.
    Paul
    Gastek Pool & Gas Services If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Check out some videos on my YouTube channel - Gastekservices on YouTube
    May 2015
    NEW YORK
    2
    It was really windy when it happened could there have been some down drafting?
    DAN MCCANN
    Jun 2012
    western NY
    1,563
    Alex, I will take "clogged up heat exchangers" for $1000
    This is what the roll-out switch is there for. DO NOT bypass it
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    Im not sure a clogged tube would generate all that heat before the heater finally quit (gas line got hot? Wow...). My guess would be maybe the down draft, rats nest, or a sooted exchanger. I think you had more heat rolling out than flame. That would explain the melting before the fuse shut the heater off.
    Factory Warranty Station for:
