Page 1 of 2 12 LastLast
Results 1 to 20 of 28
Thread: Help Me Please!!!!!!!!
    May 2015
    Columbus / Ga
    8
    Yesterday I went to the pool store to get my water tested, here are the results:
    FAC=0
    TAC=0
    CH=90
    CYA=60
    TA=80
    pH=7.4
    Copper=0
    Iron=0
    TDS=300
    PHO=0
    So i added 6 bags of POWER POWDER PLUS, 1LB each. Filter running.
    Today i woke up to a mint green pool with white foam everywhere...had the water tested again today, here are the results:
    FAC=.5
    TAC=.5
    CH=100
    CYA=0
    TA=50
    pH=7.4
    Copper=0.6
    Iron=0
    TDS=300
    Pho=0
    Leslies pools conducted these tests.. i bought some metal free for $26 and 4 Gallons of liquid Chlorine
    Tired of spending money on Chemicals...I feel like everytime I get my water tested i need more chemicals.
    or they are ripping me off.. I just wnat to swim..
    Help please......................
    17x36, 22K IG, Vinyl pool
    Hayward Variflo XL S220T Sand Filter
    Hayward Super Pump 3/4HP
    K2006 Test Kit
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Help Me Please!!!!!!!!
    Welcome to TFP!
    I would suggest tou get your own test kit to really take over your pool.
    There is no way you could have lost 60 Cya overnight! Their testing is wrong and inaccurate. You would have had to add a lot of water tou your pool to make this happen.
    Also unlikely that your TA went from 80 to 50 overnight.
    You need to flow the TFP methods. Bleach or liquid chlorine is all you need.
    I imagine the powder power plus you added could have had copper in it and that is why you now have copper.
    The 2 readings do not add up at all. They are both inconstant. I recommend the TF 100 test kit in my signature and you avoid the pool store except to buy liquid chlorine.
    You need to get some FC in there ASAP before you get an algae bloom.
    However it is hard to say how much liquid chlorine to add since we don't really know what your CYA truly is.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Jun 2014
    15,221
    Oh my! Well, get ready to hear this many, many times ..... "Stay away from the pool store." Their test results are notoriously bad, misleading, and cause you to purchase items you don't need. There's no way your CYA would be 60 one day and 0 the next. So that's just one example of bad test results from the pool store. Do NOT buy any chemicals from them. Most are just a waste of your time (except liquid shock (which is strong bleach) or granule stabilizer (for CYA)). If you stick with this site and the TFP methods, you will be much happier and see overall success.
    If your water is changing color, it means you have algae beginning to grow. You need to kill it with chlorine, nothing fancy, just simple bleach from the grocery store (or the liquid shock you just bought). How much do you need to put in? That can't really be answered "accurately" right now because you don't' have a good test kit of your own. Please see my signature for advice on how to get your own test kit - NOT the ones they sell at the local pool store. Many of us recommend the TF-100. You MUST have your own test kits (as recommended) to take accurate tests. From there, we can help you with the chemicals.
    You may want to be prepared to pick-up a few more gallons of "Regular" bleach from your local grocery or hardware store. You can add a couple gallons for now, but until you get your own test kit, we're just guessing. Also, please see the Pool School link in my signature for some really good guidance. You will most-likely need to follow the "SLAM" procedures as soon as you get a kit. Keep us posted! Lots of folks here will help.
    ha ha. Some of us were thinking and typing the same thing at the same time.
    robdac's Avatar
    Jun 2014
    Weston, FL
    232
    You need your own test kit. There is no possible way to go from a 60 CYA to 0 in one day. If they can't measure that they can't be relied on to measure anything else.
    1. Get the TF-100 test kit. It's the best deal going.
    2. Do your own testing. A patient novice with good kit beats the store any day.
    3. Only add what your pool needs. No more, no less. You'll need to know how much water the pool holds. Pool math.
    4. Understand why you are adding it. Pool School.
    5. Be patient and ask questions.
    11K gal IG screened-in plaster pool w/ spa
    pentair 150 cartridge filter, Pentair Intelliflow VS pump,
    Aquarite AQR15 SWG, AquaCal Heatwave Heat Pump, TF-100 test kit
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,193
    Welcome to TFP!!
    The first thing I will say is stay calm, anything can be fixed....
    If you have read around here much you have probably seen that not much credence is given to pool store testing. While you would think that a "professional" would be the best, unfortunately in most cases it is quite the opposite. Between employees who blindly trust the word of chemical sales representatives and high school kids working in the pool store for the summer you end up with poor results from their testing. In my case two different pool stores told me my CYA was "fine", around 70 or 80. When I tested myself I found it over 200.
    To follow the pool care methods taught here you need to arm yourself with the knowledge and tools necessary to care for your pool.
    The knowledge is condensed in the Pool School link at the top of every page. It is a great community here, but we do ask that you read and try to understand the information being taught. Questions are always welcome and folks will try to direct you and teach you the methods.
    The tools are not limited to the brushes, vacuum hoses and other stuff you use around the pool, but include the most important item - one of the recommended test kits. You can buy a kit at a pool store, but again the pool store kits generally won't cut it. To effectively practice the TFPC methods, the FAS/DPD chlorine test is essential. All these kits contain that test while very few other kits do. Think of it this way, do you see a doctor blindly prescribing drugs without seeing the patient or having tests run? Here at TFP we are going to ask for photos so we can see the condition of the water and are going to ask for a full set of test results.
    Support the site
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    Welcome to TFP!
    Get one of the Recommended Test Kits, I use the TF100 from tftestkits.net.
    When you get it give us some test results and get ready to SLAM Your Pool.
    Here are some of my fave Pool School articles in case you missed any of them.
    TFPC for Beginners
    ABC's of Pool Water Chemistry
    Here are the Recommended Levels for your pool.
    Here is the Water Balance for a saltwater pool.
    Here are the Recommended Pool Chemicals and how to add them.
    Use PoolMath to figure out how much to add.
    May 2015
    Columbus / Ga
    8
    I really appreciate all your help....i already put the Metal free in the pool... Now it is raining. I will put up a picture tomorrow. I have 4 gallons of Liquid Chlorine, i woul put them in the pool tomorrow. I will purchase a test kit tonight. Again thank you so much.
    K2006 Test Kit
    May 2014
    Franklin, NC
    9,193
    Quote Originally Posted by Prophecy View Post
    Don't bother wasting the liquid chlorine. Without the test kit you are shooting in the dark.
    You are ordering it on line right? You can seldom get them locally.
    Support the site
    DFW, TX
    24,509
    Make sure it is one of these. Recommended Test Kits
    ComputerGuyInNOLA's Avatar
    Oct 2012
    Mandeville, Louisiana
    604
    Welcome to the forum Prophecy. You are on the right track by landing here. Listen to the advice offered and learn as much as you can in Pool School. If I can do it, anyone can.
    Gunite/Plaster pool at 13k gallons. All Jandy with CL340 series cartridge filter, 1.5 HP Jandy Stealth pump. Jandy 1400 SWCG and PDA4 controller. Dual waterfalls. Polaris 280. Pool installed August 2012. Southern Louisiana. And lets not forget my trusty TF100 test kit!
    May 2015
    Columbus / Ga
    8
    This is my pool this morning, before i read your post Mr. Moderator, I put 10 pounds of 99.9% quick dissolve into the skimmer, 1 pound at a time, plus the 4 gallons of liquid chlorine and 4 chlorine tablets in the skimmer basket. im not adding anything else until i test the water. Can anyone explain the foam?
    K2006 Test Kit
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Looks like algaecide to me
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Last year my pool would foam if I added algecides when it was green.
    Lisa
    Beens's Avatar
    Jul 2013
    Virginia Beach, Va
    1,171
    Take the tablets back out and don't add any more power or solid chlorine products until you get your kit.
    Too much chlorine without knowing your cya can damage things so try to be patient and wait for that kit. My pool was green and foaming too when I found TFP.
    Don't worry. We can help you fix this.
    18' x 48" (42" water depth) Intex Metal Frame 6,700 Gallons
    Hayward Power-Flo LX 1.0 HP pump
    Hayward Pro Series S166T Sand Filter
    Original Intex Floating Skimmer
    robdac's Avatar
    Jun 2014
    Weston, FL
    232
    Relax. The pool isn't going to look like this for much longer. Until you get one of the recommended test kits nobody will know exactly what's wrong with the pool. So, until the water is tested they can't help you figure out how to fix it. Once you get the kit you'll be on your way. Let's figure out where we're going before we start driving.
    May 2015
    Columbus / Ga
    8
    Thanks Beens, i will remove the tablets. One of two local pool stores here had the K2006 test kit,, but they are selling it for $115. THATS WAY TO HIGH. It just further lets me know they are rip offs. This very frustrating and to see how many people trust there advice without knowing anything. Someone said yesterday it is like being prescribed medicine without being seen by a Doctor. Should i turn my filter off?
    K2006 Test Kit
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    I would leave filter on 24/7 so water can filter as much as possible. Backwash when psi raises 20-25% above clean PSi
    Lisa
    May 2015
    Columbus / Ga
    8
    Ok thanks
    K2006 Test Kit
    May 2014
    Franklin, NC
    9,193
    We will get your pool clear and you swimming!!
    Order a TF100 and at least include the XL option. That will give you what you need while you are clearing the pool, and probably enough reagents for a couple of years normal use.
    I also have the SpeedStir and Sample Sizer. They speed testing and accuracy.
    Support the site
  20. Back To Top    #20
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    I know you don't want to hear that you should spend more money after getting ripped off by the pool store, but a proper test kit is THE most important tool for you to take control of your pool. The rest of the chemicals you'll need can be gotten without stepping foot in the pool store ever again (unless they have a great deal on bleach or acid and you can wear your ear plugs in the store). Yes, the TF-100 kit is sold by one of the site owners but no one else here giving you advice benefits one bit from you purchasing a kit from tftestkits. And it's the best value of any appropriate test kit with great customer service. You can also opt for the K-2006 through another source and it will work just fine. We're all just pool owners like you, trying to help each other out.
    Isolated Spa - 345 Gallons
