Results 1 to 7 of 7
Thread: Water getting a little cool!
    Jun 2008
    Marana, AZ
    347
    I went swimming on Saturday. I had minor surgery on the 7th, so this was the first day I was allowed. I hadn't been in the pool since the 4th, and we had a few evenings that got down to 40 degrees, although the daytime temps have still been in the 80's, and even still a few 90's. Anyway, I had the solar cover on the pool, but the water still was about 75 in the top layer, and felt more like 70 or so at the bottom. Quite a bit cooler than the first weekend of October! My husband laughed at me.
    Above ground soft side Omega pool
    20 feet diameter, 4 feet deep
    Hayward sand filter
    Hayward 1 HP Matrix pump
    Hayward Aquabug Automatic Pool Cleaner
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    479
    Re: Water getting a little cool!
    My pool has been closed for 5 weeks. Calling for wet flurries tomorrow.
    40 x 16 IG Vinyl. Goldline SWG
    160 Sq Ft Roof mounted solar array
    2014 Hydropool Serenity 5000 Hot Tub
    The Pool School- A great place to start
    Jason's Pool calculator
    Jul 2007
    Waterford Michigan
    36
    Mines been closed now for 4 weeks and I'm already for SUMMER.
    15x30 AG
    Cartridge Filter
    Solar Heater
    1.0 HP 2 Speed pump
    + 2 KIDS
    Apr 2008
    Central Texas
    326
    Ours is too chilly for me, but the kids are still swimming a bit.
    26,000 Gallon Gunnite IGP
    2 HP Challenger High Head Pump
    60sf Nautilus DE filter
    Polaris 280
    Oct 2007
    Queen Creek, AZ
    27
    Ours is too cool for me to swim (73F in the afternoon), but DH went in yesterday. Maybe next year we'll get a solar cover and extend the season a bit.
    Built 3/08: 12x30 IG gunite/plaster play pool w/ in floor cleaning heads & auto water leveler, (10,584 gal), two Jandy Stealth SHPF 1.0 hp pumps, Jandy CL460 cartridge filter, Taylor K-2005 test kit.
    Butterfly's Avatar
    South Carolina
    10,045
    Temp was 59* this afternoon ...........but the water is beautiful!
    You're done SLAMing when:
    Mar 2007
    Coastalish 'down easter'
    4,160
    A LITTLE cool?????
    I have to dip my arm up to my armpit into numerous pools every day to close them. It was OK when the pools were in the upper 50s, but now we're getting below freezing every night and the temps are dropping rapidly! The coldest one I've had to do so far was 42*, if their thermometer can be trusted - I had 5 low returns & suctions to plug <BRRRRR> water that cold actually hurts to put your arm in for more than a few seconds And since we plug the lines while they're blowing, the water will percolate up and over the deck so I'm also getting my back sprayed, my ponytail soaked (which then drips cold water down my back for a few minutes) and the deck is soaked, so I have to lay in the cold water and soak my pants
    It's not gonna get better, but at least the closings are almost all done
    Luv& Luk
    -Ted
