Hi all,
So I read the green install sheet before I read the manual and installed my flow switch before the cell and right after a 90 degree elbow. For me to put the flow switch correctly I have to rip everything out I just did. My question is, is it even worth trying to turn on the pool with the switch installed after the 90 degree? Is this just an recommendation or will it surely fail? Plus, no where does the cell tell you which is the front and which is the back. Can that be installed wrong or does it go a certain way?
Thanks for the help and suggestions.
Here is a pic of my install. And if I have to swap it than my 2nd question is. Are they unions that connect the cell easy to get at a local Lowes or is this something Hayward only makes. I have not tried to look at the O-ring match up.
