Thread: New Pool - Adding Salt
    tackettaj's Avatar
    May 2015
    Mooresville, NC
    47
    Brand new IG salt water pool. The builder stopped by yesterday to put in the salt. I was expecting to see a ton of bags unloaded to bring the salt levels to 3000-3100 ppm. He unloaded 5 bags and dumped them in. He left two more bags and said that if the readings were not above 2500 ppm go ahead and add 1 bag, wait 24 hrs and then check it again. Everything I have read told me that 5 bags wouldn't be near enough for a 25,000 gal pool. I checked by that evening and the salt level was only at 1800 ppm so I went ahead and added the two bags he left. I now have it at 2200 ppm. Everything in me says to go ahead and buy another 3 bags to get it above 2500 so cell will begin producing chlorine. Brand new to this so I was looking for some expert advice to either confirm my thinking or tell me I'm crazy.
    -25,000 gal. freeform gunite, smooth quartz finish w/ spa
    -2 hp Jandy Pro Series Stealth; Jandy Pro Series Cartridge Filter (CV340)
    -Jandy Pro Series AquaPure Chlorinator; Jandy Pro Series JXi Heater
    -Zodiac MX8 cleaner; Taylor K-2005 DPD Complete Chlorine Kit
    Jun 2014
    Toronto, ON, Canada
    98
    Re: New Pool - Adding Salt
    How many lbs per bag? Pool math says you need 523lbs of salt to raise concentration 2500ppm in a 25000 gallon pool.
    If 7 bags raised you to 2200ppm, then you only need 1 more bag of the same weight. Pool math says 460lbs of salt would give you a 2200ppm rise, so that means your bags were 65lbs/each?
    12' Intex Metal Frame Pool, 1500 gallons, Intex 2800gph Sand filter/pump, AquaPro PRO1100 HP, K-2006 Test Kit
    May 2015
    Brooklyn NY
    46
    Hello and welcome. I am far from an expert but last year got my new 6000 gallon above ground with a salt water generator. I added 3.5 50lb bags to get my salt level at 3000. For a 25,000 gallon pool, I would say you need between atleat 8-9 bags of salt. 5 bags is definitely not enough. Go with your gut and buy 4 more bags and I would easily spill an additional 2 and watch the levels go up. Make sure you brush the bottom of the pool to help the salt circulate and not allow it to sit on the floor. To help with filtration and movement of salt, I attached my vacuum during the first day of salt adding and scrubs the floor so that it would filter both on thop of water and also lower on the floor. Good luck.
    Salt Water 8000 AGP 12' X 18' X 54" - Hayward S166T 16" Sand Filter w/ 1.5HP Power-Flo Pump - Hayward Aqua Trol RJ Salt Generator System
    tackettaj's Avatar
    May 2015
    Mooresville, NC
    47
    Thanks for the reply!
    That's what I thought also and was expecting to see way more than 7 bags unloaded out of his van. He dropped off 40 lb bags. If I figured correctly by adding 1.5 (40 lb) bags will bring it to 3000 ppm. Just wanted to make sure I wasn't missing something.
    tackettaj's Avatar
    May 2015
    Mooresville, NC
    47
    Quote Originally Posted by lasercomp View Post
    Thanks lasercomp...sounds like I'm headed in the right direction. The two bags I dumped last night was followed by brushing the salt around and then turning on my suction cleaner. Thanks for the advice!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Welcome to TFP!
    Get one of the Recommended Test Kits, I use the TF100 from tftestkits.net.
    Here are some of my fave Pool School articles in case you missed any of them.
    TFPC for Beginners
    ABC's of Pool Water Chemistry
    Here is the Water Balance for a saltwater pool.
    Here are the Recommended Pool Chemicals and how to add them.
    Use PoolMath to figure out how much to add.
