Results 1 to 12 of 12
Thread: Liner Issue - Bump/Protrusion
    Oct 2011
    Chicago, IL
    113
    I just opened my pool and I noticed a protrusion in the liner of my pool. I had this liner installed within the last 3 years. It is a sunken above ground pool. it is concrete bottom with wood on the sides with a custom vinyl liner (very expensive!). The protrusion is on the bottom of the pool on the angle down to the deep end. I didn't really notice it in the past, so I think this may be new. It looks to be about 2-4 inches wide, but I haven't gone in yet to inspect further.
    I am not really sure what it could be since this is a concrete bottom. I poked at it with my pool brush and it seemed pretty solid. I dont have any nearby trees that would be causing the issue with roots. When the company installed this liner they did some concrete work, nothing major but I think it was just to make it smoother for the liner. See links below for a couple of pictures.
    IMG_0757 1_zpswucvvwqu.jpg Photo by dellapor | Photobucket
    IMG_0756_zpscmf5spmt.jpg Photo by dellapor | Photobucket
    Any ideas what could be causing this? I am afraid whatever it is is going to bust thru the liner.
    I have a 35,000 gallon, sand filter, sunken above ground (so inground), vinyl liner, with an Aqua rite turbo cell SWG
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Liner Issue - Bump/Protrusion
    Could it be a root from a nearby tree?
    Oct 2011
    Chicago, IL
    113
    There are trees in the lot next door but this bump is on the side closest to house so I doubt that's the issue. It would have to go all the wayunderneath the pool and pop out on other side. And even then the tree is pretty far away from the pool
    Isaac-1's Avatar
    SW Louisiana
    6,711
    No idea then, sink holes are far more common under vinyl liners
    Oct 2011
    Chicago, IL
    113
    thanks for the input Isaac, I am hoping whatever it is miraculously goes away. I am afraid its going to poke thru my liner and if that happens there is no way I will be able to replace it again.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    If it does poke through then maybe you can see what it is / remove it then patch the liner.
    Oct 2011
    Chicago, IL
    113
    So you can patch an area that big, like 3inches around? I have never had to patch before so curious if that would be a legitimate option. Just trying to alleviate any unnessecary stress because the last liner set me back quite a bit!
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Yes, it is possible to patch something that size
    Oct 2011
    Chicago, IL
    113
    wow what a relief!!! thanks again for your input!!!
    Oct 2011
    Chicago, IL
    113
    Hi everyone, popped off the pool cover today and noticed some more of the tennis ball shaped bulges. What the heck could be causing these? The liner is only a few years old. The last one was like 12 years old and there were no bulges at all. Definitely not an issue with roots here. I am so confused!
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Too cold to get in and feel it? (I'm guessing it is, but that may be the only way to know for sure wheat it feels like.)
    Oct 2011
    Chicago, IL
    113
    A couple of them were there last year, they are rock hard. Definitely too cold right now!
