Results 1 to 7 of 7
Thread: Lurker turned TFP rookie.
    Hello all. Just opened up the pool for this year and will be using these methods now. Was using pucks before but will be switching to bleach. Measures CYA a few days ago and it was 130. Since I am just getting started for the year, I figured I might as well do a partial drain and try to fix it. So I let out about 3/4 and refilled today. Here are new readings. FC was very high before refill.
    TA 120
    Ph 7.2
    FC 5
    Calc 240
    Cya 70 (ish?)
    I was surprised to see chlorine was so high. I still have some pucks in the chlorinator which I guess I will let finish off. I live in New Mexico, lots of sunlight, so I think the new Cya level, while high, is still acceptable?
    I added a bit of borax to try to get the PH to 7.5, as recommended by the pool calculator. How do these numbers seem to you guys? I did not have time to check the CC yet. Water looks great. Another question I have is, using only bleach from A big jumbo box store, how much can I expect to add on a 1-2 day basis? Just a few cups? Any other advice would be greatly appreciated.
    Thanks
    Pete
    10k gallon in ground gunite pool. Cartridge filter. Gas heater. Sunny New Mexico.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Lurker turned TFP rookie.
    CYA is pushing it for a manually dosed pool, I would remove those pucks, and consider another 20% drain and replace. Your FC is also at the minimum for a CYA level of 70 so you should boost it with bleach / liquid chlorine.
    Pool School - Chlorine / CYA Chart
    Ike
    p.s. In general CYA should not be above 50-60 ppm even in prime sunbelt locations on a manually dosed pool
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Chlorine usage should be 2-4 ppm per day.
    Here are some of my fave Pool School articles in case you missed any of them.
    TFPC for Beginners
    ABC's of Pool Water Chemistry
    Here are the Recommended Levels for your pool.
    Here are the Recommended Pool Chemicals and how to add them.
    Use PoolMath to figure out how much to add.
    All right. Drained about 1/3 overnight and refilling now. Do most people manually add chlorine or get an automatic injector? I work quite a bit so automation would be ideal. Is there anything I could easily replace the tablet feeder with to inject chlorine? I'm looking for something without too much startup cost. Will report back with new numbers this afternoon. Thanks guys!
    DFW, TX
    24,485
    Once you get familiar with your pool and its chlorine usage you can add once per day or even once every other day in many cases.
    Automated chlorine options include
    Stenner pump
    Liquidator
    saltwater chlorine generator
    My choice is SWCG. There are lots of posts from people describing their installation of Stenner and Liquidator systems. Search top right.
    Jun 2014
    Michigan
    62
    2nd year rookie here. Follow these cats !!!! Fired the pool place cabbage scoopers ! Spent 10 to open the pool This year instead of 200 ish.
    Am also looking at a inexpensive do it myself chlorine drip system. I have a frogger system installed but since going to BBB she is dormant.lol looking to modify or replace that section with a liquid bleach drip system so I will follow this !!! Good luck !!!!!!
    Anyone figure out how to modify a chlorine puck floaty device into a liquid chlorine dripper ? Momma loves her floaty. Lol
    Sent from the deep end using Tapatalk.
    20K gal, Fiberglass, 1.5 hp Century Pump, Sta-Rit System 3 Model PLM-100, 100 SQ Foot. Inline Frogger Chlorinater Mineral pack removed, adjusted the Chlorine pac to put in my own when on vacation. Liquid Pool Sanitizer,, BBB style.
    Sounds good! Workin out the details so I will follow up when I'm done
