Thread: Florida pool new owner - evaporation with waterfall rock feature.
    May 2015
    jacksonville, Florida
    15
    I live in Florida and my pool is uncovered and in direct sunlight most of the day. It has a waterfall over rocks feature so when the pump is on, the water flows over the spa and waterfalls over the rocks into the pool.
    I read online that standard pools may lose 1/4 inch to evaporation a day but I'm seeing more like 1/2 inch. Is that normal given my location and more so perhaps the waterfall rock feature? Logic tells me that more water will evaporate over the hot rocks. Is this true?
    Would it be wiser to move my pump time to like 4am to 12 pm so it's not on during the hottest moments of the day? Right now it's 8am-4:30pm.
    I'm just paranoid about leaks and problems and just curious what's normal and how I figure out if it's normal.
    Thanks for any advice!
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Florida pool new owner - evaporation with waterfall rock feature.
    I would put it in the normal range, depends on your humidity
    May 2015
    15
    Thanks for responding. What do you think about shifting the pump on time? I read in this forum that 8 hours a day isn't necessary but I'm not sure how I could determine how long I should use the pump. The company that maintains the pool knows it's on 8 hours a day and hasn't suggested any changes. It's a salt pool.
    I'm still neurotic about the leak and may call someone but figure I'm gonna drop a bunch of cash to just get peace of mind I guess.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Welcome to TFP!
    Don't spend the money yet. Do a search on the forum here for a bucket test. Doing one will confirm a leak or no leak. It doesn't sound too terribly out of line.
    As for running the pool, you'll have to find the least amount you can run it with the proper setting on your SWG to maintain a good FC residual, and keep the pool clean to your liking.
    Essential Links:
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    The bucket test info is here: Pool School - Leak Detection
    As for run time run it as little as you can daily and still have your pool clean, skimmed and make enough chlorine. Just experiment with the run time until it is working well for you. It will change with the seasons anyway.
    PoolESQ's Avatar
    Dec 2007
    Albuquerque, NM
    191
    If you start running the pump (and waterfall) at night, it will save water but a possible negative side effect will be cooler pool water.
    Replastered 2015: Sunstone Quartz Midnight Blue 16x32 rectangular gunite with in-pool spa....18,000 gallons. Autopilot Total Control System with SWG and acid pump. Pentair Clean & Clear 420. Auto cover. TF-100.
