Thread: Air leak somewhere? Pump Issues.
    May 2015
    Abbotsford
    2
    Here are the details.
    20x40 pool 9' deep. In-ground pool vinyl liner.
    Pump and sand filter are in a separate shed.
    Under normal operation and filer all is ok.
    When I attach my vacuum or Kreepy Krawly directly to the skimmer, the pump works for a while then starts to pull air. Then the pump re primes itself, pumps for 10-20 seconds then looses all suction again. This process repeats itself over and over.
    Can anyone suggest anything?
    I don't want to think my underground pipe from skimmer to pump might be broken and have a leak... since the pump only starts to suck air when there is excess resistance on the suction side at the pool skimmer. uugh.
    Thanks in advance.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: Air leak somewhere? Pump Issues.
    Welcome to TFP!
    I haven't had to fix a suction side leak before. Here,is an article from pool school that should be helpful.
    Pool School - Suction Side Air Leaks
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Suction side air leaks can be hard to located, and are often a process of elimination, you can use a water hose on suspected leak sites to see if it stops the air getting in, or sometimes shaving cream to spot the leak if it is above ground.
    Ike
    p.s. can you tell us where Abbotsford is located, often knowing where you are can influence our answers to questions
    May 2015
    Abbotsford
    2
    Well found the issue. Just at skimmer. Rubber couplers had been used at some point. And my mother put in a on off timer. And was putting chlorine pucks in the skinner hence the water became super acidic and ate away the rubber. Phewf. Found now fixing it. Abbotsford is near Vancouver bc.
    20x40 inground with vinyl liner. 9' deep. Hayward pump and sand filter.
    DFW, TX
    24,497
    Excellent news! Please update your location in your profile for future reference so it shows up over there
