Thread: Hello,, from boston
    Hello,, from boston
    Hello,, from boston i will install my pool this summer
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Hello,, from boston
    Welcome to TFP!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Hi Jochy, Welcome to TFP!
    Essential Links:
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Welcome to TFP! We will be here to help when you are ready. I am sure you are reading through pool school and the recomended kits as you are waiting.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Welcome to TFP! Congrats on the new pool!!
    Get one of the Recommended Test Kits, I use the TF100 from tftestkits.net.
    Here are some of my fave Pool School articles in case you missed any of them.
    TFPC for Beginners
    ABC's of Pool Water Chemistry
    Here are the Recommended Levels for your pool.
    Here is the Water Balance for a saltwater pool.
    Here are the Recommended Pool Chemicals and how to add them.
    Use PoolMath to figure out how much to add.
