Thread: ph testing
    May 2015
    frankfort il
    22
    ph testing
    im testing with the taylor 2006 testing ph and get a test of 7.5 let solution sit for a minute or 2 then it reads around 8 so should you read right away to be accurate and by shaking is that aerating it will that affect test
    inground pool 30000 gals vinly liner coverstar automatic cover
    Re: ph testing
    What are the fc and cya?
    Support the site
    May 2015
    frankfort il
    22
    Re: ph testing
    fc 6
    ta 125
    ch 550
    cya 60
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: ph testing
    That happens to me, too. Just ignore the time delay. I add the drops, cap it, flip it twice to mix the drops, and get my reading.
    May 2015
    frankfort il
    22
    Re: ph testing
    ok just wanted to make sure my reagent wasnt bad
