Thread: Needing Advice...
    May 2015
    Tucson
    6
    Needing Advice...
    Howdy, all! My name is Brian and this is my first post. As you can see in my signature, I have a fiberglass pool. I just got a Taylor K-2600 FAS-DPD kit and checked my levels. Been gnashing away at my problem for the better part of six weekends now. Had an algae bloom at the end of the season last year. My filter wasn't't doing a very good job. I found and fixed any suction-side problems and bought 2 new filters. Been randomly adding 10% liquid chlorine and an algaecide and am getting nowhere! NOW that I have my test kit I have a baseline of exactly how much stuff to add. Do these numbers jibe with you all?
    FC=1, so I need four gallons of chlorine to attain shock level
    CC=.6
    CYA=60 full sunny Tucson exposure
    TA=60 need to add 127 oz. of baking soda
    PH=7.0 need to add 54 oz. of Borax
    Thank you all for looking/helping!
    13,500 gallon fiberglass, 3/4 hp Sta-Rite Max-E-Pro pump, Pentair Predator 150 cartridge filter, equipment lower than pool, Taylor K-2006 FAS-DPD kit
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,216
    Re: Needing Advice...
    Welcome to TFP!!
    Ignore TA and if you have any aeration at all the pH is going to come up on its own. Not all parameters need us tinkering with them to attain a "perfect" number.
    You had algae last year, how is it now?
    If it is clear now, I would at least bring the FC up to 10 and conduct an Overnight FC Loss Test (OCLT).
    Support the site
    May 2015
    Tucson
    6
    It'still green...naturally.ACK!!! I know I need to get it to shock level, and using the pool calculator, the numbers I showed are the numbers suggested by said calculator. Does 4 gallons seem right. Heckler, over the last 5 weeks I have dumped 24 gallons in! I realize I probably just never got it to shock level so it was all for naught. I have no aeration going on either.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Welcome to TFP!
    All numbers shown below are from Pool Math for a 13,500 gallon pool...
    Given a CYA of 60 ppm and assuming you are still using 10% chlorine , you only need 397 oz which is just over 3 gallons. This will bring your FC to 24 ppm.
    To bring TA up from 60 to 80, you would need to add only 63 oz by weight or 51 oz by volume of baking soda
    If you use Washing Soda / Soda Ash, you only need to add 31 oz by weight or 27 oz by volume to bring pH up to 7.5. This is roughly half the amount of product compared to Borax.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,517
    Welcome to TFP!
    It is time to SLAM Your Pool.
    Here are some of my fave Pool School articles in case you missed any of them.
    TFPC for Beginners
    ABC's of Pool Water Chemistry
    Here are the Recommended Levels for your pool.
    Here is the Water Balance for a saltwater pool.
    Here are the Recommended Pool Chemicals and how to add them.
    Use PoolMath to figure out how much to add.
