Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: Is my pool Cloudy? or Clear?
    Jul 2014
    Cincinnati / OHIO
    14
    I know this sounds ridiculous but i cant tell if i am being anal or not. What do you think. Do you think my pool is crystal clear? or a tad cloudy? I have passed the Over Night test. CC are <.5 and im not sure about the clarity of the pool.
    FC 17 just added 96oz of 8.25 bleach
    CC <.5
    TA 180
    PH 7.5 before slamming
    CYA 50
    Brushing and Skimming and Keeping above shock as much as possible, Running Auto Cleaner Dolphin DX4S 3 times a day with the fine filter in the cartridge.
    I also added DE to sand filter, went up 1psi and then back washed when it went up 7 more psi. I did that twice. So now there is no DE in sand filter and back to the clean 16PSI on the gauge sand filter.
    I just want a crystal clear pool.
    SHOULD I ADD SUPER BLUE i feel that maybe my sand filter is not getting it all.
    18x36 In Ground Pool W/ Auto Cover, Nature 2, Hayward 1 1/2 Pump and Sand Filter 1 1/2" pipes, 21500 Gallons
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Is my pool Cloudy? or Clear?
    Looks clear to me, but photos can be deceiving.
    Without reading back, are you still feeding the Nature2?
    Support the site
    Donldson's Avatar
    NW Ohio
    2,893
    I would call it clear enough that you can stop the SLAM, given you passed the other two requirements. As you keep your FC at proper levels you should notice increasing clarity over time. This is because nothing is growing so your filter has time to polish the water. NO need for clarifier.
    Fine job kaiswroll!
    From my HTC One via Tapatalk
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    May 2014
    Franklin, NC
    9,184
    Oops, I missed the clarifier part of the question. I agree with Donldson, no clarifier. If you feel you must do something, you can add DE to your sand filter.
    Support the site
    Donldson's Avatar
    NW Ohio
    2,893
    He did that, but I agree it is a better option than clarifier.
    Jul 2014
    Cincinnati / OHIO
    14
    Great thanks! Yes nature 2 is being fed.
    May 2014
    Franklin, NC
    9,184
    Quote Originally Posted by kaiseroll22 View Post
    Just understand that the Nature2 is expensive and is dumping stuff in the pool we do not recommend.
    Support the site
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Nature 2 is adding metal to your water. Expect green stains and green hair if you keep adding mineral packs
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    VetteBlue's Avatar
    May 2015
    Maryland
    23
    Based on the shot of your bottom drains, I'd say it's slightly cloudy. But that could also be angle and/or lighting distorting the pic.
    17x35 Oval In Ground Vinyl Pacific Pool, Pentair Intellichlor IC40 SWG, Sand Filter, Pentair Kreepy Krauly Legend Pressure Side Cleaner, LED Lighting System, 16 Mil Clear Solar Blanket, TF-100 Test Kit
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    It could just be the picture, but I see slight haze to the water. Looks fairly clear other than the slight haze though.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,274
    I strongly suggest that you remove the metal balls from the nature 2 cartridge. My plaster is stained from the nature 2 and it is only a matter of time before your pool is stained, too.
    Here is my posting describing how to remove the metal without removing the entire system (with photos):
    How to Remove Metal Balls from Nature 2 Fusion
    Karen
    33K IG w spa plaster, Pentair 1HP Whisperflo, DE Filter, SWG CircuPool RJ-60, Dolphin Triton Plus, Raypak Dig 336K BTU, TF-100.
    Pool Math Chlorine / CYA Chart SLAM - Shock Level And Maintain
    2017 replaster/retile
    PoolESQ's Avatar
    Dec 2007
    Albuquerque, NM
    191
    Still a bit cloudy.
    Replastered 2015: Sunstone Quartz Midnight Blue 16x32 rectangular gunite with in-pool spa....18,000 gallons. Autopilot Total Control System with SWG and acid pump. Pentair Clean & Clear 420. Auto cover. TF-100.
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,274
    Did you add a little DE to the filter? Sand filters take longer and a little DE should help clear out the rest of the dead algae/fine sediment. Keep your filter going 24/7 until it is crystal clear. A dirty sand filter works more efficiently at clearing fine particles, too.
    Karen
    Jul 2014
    Cincinnati / OHIO
    14
    May 2014
    Franklin, NC
    9,184
    That is clear!!
    Beautiful
    Support the site
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    If you can see the drain cover philips head screws at 6 feet, I would say it's clear...
    13,000 Gal Pool & Spa
    Jandy Automation /w IAqualink
    Autopilot SWG
    Jandy 2.0 HP VSP, Filter Cartridge
    Taylor (FAS-DPD K-2600, Pool Surface: Plaster
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Definitely clear! Nice pool!
    Jul 2014
    Peoria, IL
    389
    Very nice. Did you ditch the Nature 2???
    I use it in my hot tub but went SWG in the pool.
    30x20 vinyl IG, Hayward SD60 with Pentair Dynamo 340219 2HP pump, Compupool CPSC24 SWG, Hayward H200FDN heater. APC automatic pool cover.
    Central Illinois
    Jul 2014
    Cincinnati / OHIO
    14
    Nature 2 is still being fed but not with the low fc .5 that nature 2 says. I'm trying keeping it at 3 FC. And most likely won't use the nature 2 next year and go to SWG.
  20. Back To Top    #20
    Donldson's Avatar
    NW Ohio
    2,893
    At 50 CYA your minimum FC is 4, if you don't keep it above that then your water will likely not be staying clear.
