Results 1 to 11 of 11
Thread: HELP!! Havy rainfall...now what's wrong??
    First Pool Judith's Avatar
    Feb 2014
    Georgetown, Texas
    57
    We're in Austin, TX and have been getting massive amount of rain. My pool looked fine this morning. Now the water looks very cloudy - I can hardly see the Polaris at the bottom. If I had to guess, I think the water from my yard may have been running into my pool? Just a guess as we were not home today. What should I do?
    Chlorine tested at 3 (normally keep it at 6.5)
    Ph 7.8
    Alkalinity tested at 50 - normally keep it around 80
    Please advise. Should I shock??? This has never happened before so I don't know what to do.
    Thank you!
    Judith and Brian D
    16,000 gal; IG Quartscape; Cartridge Jandy CV460 (150 gpm Max); Jandy Pro 2.0 Variable
    Polaris PB460 3/4 booster; Polaris 280 Cleaner; In Line Chlorinator Tri-Chlor (don't use it) Ozonator
    Fill Date 11/11/2013
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: HELP!! Havy rainfall...now what's wrong??
    Yep, we been getting a lot of rain up this way as well.
    Quote Originally Posted by First Pool Judith
    Ph 7.8
    What are you using to test with? One of the parameters that is missing from your results is CYA (a.k.a., stabilizer) . The amount of chlorine you need to maintain depends on the CYA level as illustrated here: FC/CYA Chart.
    Now for what is causing the cloudiness, it very well could be runoff. Keep in mind that runoff can introduce microbes into the pool. If your chlorine is too low for your CYA, that can give algae an opportunity to gain a foothold. The proper amount of chlorine, and chlorine alone, will prevent algae. That's why we need to know the CYA level so we can determine if your current chlorine level is adequate.
    Three things I would recommend: (1) Remove as much debris as you can from the pool. This will reduce the chlorine demand, (2) Get one of the Recommended Test Kits, and (3) read the ABCs of Pool Water Chemistry article.
    Feb 2014
    Georgetown, Texas
    57
    I'm using the Taylor 81-330 and for chlorine I use the R-0870 DPD test. My CYA is normally around 50-55 and it is still so, I just did the test. The calcium hardness is 330.
    Thoughts? Do I shock? Leave the pump on high, or... something else?
    Judith and Brian D
    Feb 2014
    Georgetown, Texas
    57
    Thoughts anyone?
    Judith and Brian D
    30,405
    If rainwater is flooding your pool, there is nothing to do until it stops. It will be a long process to clean out usually.
    Post a pic in the AM and let's see how bad it is.......I doubt you can help it tonight.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    You likely need to follow the slam process Pool School - SLAM - Shock Level And Maintain
    Ike
    ps your massive rains just hit here about 10 min ago, we have severe thunderstorm and tornado warnings going on
    Mod Squad pooldv's Avatar
    DFW, TX
    24,460
    You only need to shock if you see signs of algae.
    Filter clogs quickly and often
    Pool walls slimy
    High chlorine usage
    Cloudy water
    Or Perform the Overnight FC Loss Test (OCLT)
    Feb 2014
    Georgetown, Texas
    57
    OK here are the results from this morning an a pic.
    Today's numbers:
    FC: 6.8
    PH: 7.6
    TA: 70
    CYA: @53
    I did also perform an Perform the Overnight FC Loss Test - no loss of chlorine
    The pool looks much clearer this morning. Thoughts now?
    Judith and Brian D
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    I think you are fine. I've had some heavy rains do that to. Just keep your FC up and run the filter 24/7 until the pool is crystal again.
    I'd elevate the FC to 8 for a few days.
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    Feb 2014
    Georgetown, Texas
    57
    OK - thank you!!
    Judith and Brian D
    Pops37's Avatar
    May 2013
    North central TX (Tarrant County)
    108
    It will pass with a little extra TLC. I agree no need to shock unless algae . Filter extra to remove yard run-off. Might even consider dump 10% and hope for less rain. Truth is all TX needed the rain to bad it came all at once. Some people suffered family losses so sad. Anyway, I suggest dump excess up to 10% filter lots, If large stuff then vac or basket out. Then adjust chemicals as usual. Good luck.
    Gunite/plaster pool w/spa built 1983, 17,000 gal. (depth 3' x 6' x 3') (37' X 16' +spa, stairs & large in-pool bench seat). Arneson (now Hayward) pool vac (rebuilt 3 or 4 times over 30 years), 350k BTU (nat gas) XE heater (in need of a serious herbal cleansing lol), 2HP Marathon pump & filter basket, DE filter NSS-48, air pump for spa bubbles, one skimmer plus in-line filter Hayward CANISTER W560 to the pool vac. Re-plastered May 2013 reinforced quartz (Marbletite) Diamond Bright. Test kit: Taylor K-2006; Bleach
